Hi,
If anyone can help it would be greatly appreciated. I've seen many posts with this problem and all hav solved it. I've tried everything suggested on every post and nothing has worked. I am not getting any fuel to the TBI and the ECM b fuse blows whenever i turn the power on. I have already replaced the oil pressure sensor, fuel pump, fuel pump relay (I think I have anyway), and the ignition control module. I had the coil checked and that was fine too. Please, I will take any feedback. Also, I'm not exactly sure which relay is for the fuel pump. I have 4 on the driver's side. |
Re: 86 S15 Jimmy ECM b fuse keeps blowing
My try posting this in the S10 forum.
http://www.67-72chevytrucks.com/vboard/forumdisplay.php?f=130
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Oh. Thanks. I didn't know.
