02-01-2008, 03:30 AM | #1 |
Its Topless Season!!!!
79 1/2ton disc brakes.......
Will these bolt right up to my 69? I think I am getting a good deal for a complete setup..but wanted to know is there anything i need to look out for
02-01-2008, 03:49 AM | #2 |
Re: 79 1/2ton disc brakes.......
Are you getting the spindles also? If not you need them. Also make sure they are the heavy duty breaks. The rotors will be 1.25in thick. The light duty will be 1.0in thick. The H.D. will also have a 1.375 dia. inner bearing and the L.D. will have a 1.25in inner bearing. You will need to replace all ball joints, master cylinder, proportioning valve, brake lines, outer tie rod ends and get tie rod adapter sleeves, unless you upgrade all of the steering linkage. All parts are from the same year of your disc brakes except the adapter sleeves. You can get them through C.P.P. Hope this helps!
