Old 02-01-2008, 09:20 AM   #1
BCOWANWHEELS
Instrument Cluster Question
I have a non- full gauge cluster in my truck and i just got a cluster from another truck that has the water temp. , oil pressure and volt gauge in it. my question is - is it a straight foward swap out or is the wireing harness different ? i know i have to run a oil line to the block as its a mechanical gauge also the speedo cable will hookup with no problem. any helpor tips would be appreciated.
bob in tn.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-01-2008, 09:31 AM   #2
C. M. Wolf
C. M. Wolf's Avatar
Re: Instrument Cluster Question
If you didn't have an oil line before, you'll need to run one,(of course). Other than that it "Should" wire right in. (I have to tell you, I just can't see it from here, so it's hard to say). As long as both model trucks were the same and the years coresponding to mfg'r years, it should go right in.
What year and type truck are ya talkin anout here?
Michael
P.S. I'd recommend changing out any heater hoses while you're in there,(cleaning things up inside that dash area, checking for any worn wires, etc, sure couldn't hurt while the area is open).
C. M. Wolf is offline   Reply With Quote
Old 02-01-2008, 09:35 AM   #3
Hutch
Hutch's Avatar
BCOWANWHEELS
Check out the tips page from GMC pauls web-site
http://www.gmcpauls.com/Tech%20Tips1.htm]
Also check out his site while you are there
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-01-2008, 10:36 AM   #4
Andy4639
Old member
Andy4639's Avatar
No!!!
It's not a direct bolt in. The gauges or all prewired where your no gauge isn't nothing but lights. You should get the dash and motor wiring for the gauges too.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-01-2008, 11:19 AM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
If you don't change the underhood harness to a gauge setup you will let all the smoke out! It must be changed...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-01-2008, 11:28 AM   #6
haysonj
haysonj's Avatar
I'm not sure but my painless wiring kit is the same for idiot lights or gages the only thing that didn't work was the ammeter Now you may have to change the temp sending unit because I think it is two different part numbers
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-04-2008, 12:17 PM   #7
BCOWANWHEELS
thanks guys your all the best...... best web site on the net.
bob
Old 02-01-2008, 01:54 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
this was the first mod in my first truck... I ASSumed that since the plug was the same, that it was a straight up swap.
It isn't.
Trust me.
I can still hear my buddy literally rolling in the dirt laughing his ass off as the needle on the fuel guage spun around a few times before expiring in a puff of smoke.
Old 02-01-2008, 02:05 PM   #9
crazy longhorn
Fabricate till you "puke"
It isn't.
Trust me.
.....sorry man, but I could just see your bud rollin in the dirt laughin on that one(maybe the fuel guage thought is was a clock?) GMC Paul has some tech info on what wires to swap on that install. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-01-2008, 02:11 PM   #10
Longhorn Man
I can still feel the sinking feeling in my gut. Almost 11 years ago, and it feels like it was last summer.
I soooooo wanted to kick him while he was rolling in the dirt.
Alcohol may have been involved. (in his behalf)
Old 02-01-2008, 07:03 PM   #11
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
AFTER you read GMC Paul's FAQ, it is really easy. Some of the wires are hard to get out of the connectors, but patience helps. You will also need a different temp sending unit,local parts store has them about $10. Ask for gauge unit, not idiot lights. Parts store also has oil line kits with different size adaptors to fit engine block. You will end up with one extra wire(oil pressure seending unit) and luckily it's the same color as 2 turn signal wires. So check operation before you install cluster.
P.S. Bob, I'm still coming to J.C./Kingsport once a week so if you need parts smuggled across the state line P.M. me
Todd
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 02-02-2008, 03:23 AM   #12
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Its really an easy swap to do though. I set up one for one of my buddies, in his 67. Only had to move like 2 wires in the harness. Like retodd said, Paul's FAQ is easy to follow.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 02-02-2008, 08:11 AM   #13
short step
get a elect sender for the temp & oil pressure and try this
http://www.boomspeed.com/bofh1968/ch...ng_diagram.pdf
short step is offline   Reply With Quote
