Old 02-08-2008, 01:10 AM   #1
DANTIP
DANTIP's Avatar
Unhappy HELP! My Throttle Cable Pops Out!
My throttle cable doesn't want to stay in the bracket attached to the 4bl carb. It kind of slides out. Am I missing a keeper or something?
Dan
DANTIP is offline   Reply With Quote
Old 02-08-2008, 01:47 AM   #2
Premium72
Premium72's Avatar
Re: HELP! My Throttle Cable Pops Out!
haha. no really,. what dort of bracket is it? can you snap a pic. not sure what you missing without knowing what you have.
Premium72 is offline   Reply With Quote
Old 02-08-2008, 02:39 AM   #3
mrein3
mrein3's Avatar
If you're running an Edelbrock style carb, you need a "throttle rod stud". The one I bought is an Edelbrock piece. I bought it off of a recommendation here. I put it on when I installed the carb and except for when I attached the aftermarket cruise control, I haven't touched it.
I hope this helps.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-08-2008, 05:39 AM   #4
mrein3
mrein3's Avatar
I hope this helps.
Nevermind. I thought you were talking about a throttle rod, not a cable.
One thing to consider. If you look in the picture I posted, the gold colored bracket I used for my th350 kick-down cable was also an Edelbrock piece. I had a straight stick previously and with the throttle rod, I had no kickdown/throttle cable piece. If your bracket is bad you maybe could try that piece. However I'm guessing the plastic housing that clicks into the bracket is buggered up. In which case you'll need a new cable.
'72 Malibu hard top
Center City, MN
Old 02-08-2008, 11:34 AM   #5
Joesjunk
Joesjunk's Avatar
Dan, I was having the same problem with my 72 big block truck too!! I just put a wire tie on it for now, not sure how to fix it correctly yet.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
