Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Sway bar installation question..
I think I already know the answer to this but I thought I'd ask anyway.
When installing the frame brackets on a truck that didn't org. come with a sway bar, do I need to grind out the rivets at the bottom of the front cross member to bolt the support brackets to? Seems like thats where it needs to go. Thanks |
Re: Sway bar installation question..
YEP!
The bigger head on the rivet is on the top of the frame rail. So grind from the bottom and hammer them out!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 02-10-2008 at 01:41 AM. |
Great, Thanks!
I'll go get some bolts before I grind. Last edited by DennyB; 02-10-2008 at 02:02 AM. |
Should I grease the new bushings where the bar goes through?
Phone's ringin Dude.
![]() Join Date: Mar 2007
Depends on the bushing you use. If you are using an OE style rubber bushing, slime it up a little bit, but I would reccomend going with a polyurathane bushing from a company such as Energy Suspension. They are greaseless and last a lot longer. Hope this helps.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
Thanks,
I picked up a set of Moog poy bushings and the instructions said use no lube. |
67-72 Addict!
Denny, I also used Moog bushings and didn't use any lube. My dad got his from ECE and his has little grease fittings built into them.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 02-11-2008 at 07:55 AM. |
The LuvShack Garage
Moog here also, no lube
It Is What It Is,,,,
Gotta have lube.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
