Old 02-13-2008, 01:17 AM   #1
cdhc10
What to paint frame with?
What do you guys recommend to use for painting my frame? POR, Powder Coat, or Spray paint? I am not looking for the shinny look i want a mat finsih look. Pictures of what you recommend would be good?
cdhc10 is offline   Reply With Quote
Old 02-13-2008, 01:22 AM   #2
shifty
Questionable
shifty's Avatar
Re: What to paint frame with?
You have several options. Are you sandblasting?
If you are, consider powdercoat. Powdercoating is hard as nails, wont chip or flake if done properly, and is a lifetime finish. Way better than automotive paint.
If you are not, and just plan to paint, Eastwood has several products such as "Rust Encapsulator" which is easy to apply.
POR-15 is another viable option.
I've seen some guys here on the forum use a newer product called "Rust Bullet" (it's silver and looks badass in pictures) which is similar to both Rust Encapsulator and POR-15
Make sure you read the instructions on whatever you choose, and wear nitrile gloves or similar. Do not leave the can open. POR-15 is supposed to harden instantly on contact with moisture, so ... it sticks to skin and you can ruin a whole can if you leave it even cracked a smidge.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-13-2008, 01:30 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I used Rustoleum on on of mine about 10 yrs ago and it's still holding out pretty good.
POR15 is a good product (pricey) and I've used it on other parts. The only thing I don't like about it is that if you get it on you, it's hell getting off once it dries... It's almost like a tatoo...
68gmsee is offline   Reply With Quote
Old 02-13-2008, 01:33 AM   #4
cdhc10
Yes i will be sandblasting
Old 02-13-2008, 06:38 AM   #5
AuggieStyle
AuggieStyle's Avatar
there is a place in gainsville that can powdercoat the whole thing if you dont have any one in mind to do the work, they preheat the frame then powdercoat then cure. most people will tell you that is a waste of time THEY are usually the ones doing the powdercoating (lazy) and they dont want it to last that long I guess, job security.
the thing with powdercoat is you cant have anything on the frame it has to be clean, i have not seen powdercoat on a frame that has not chipped.
i usually mar hyde one step the frame then shoot S/S black and i can reshoot chips and scratches anytime.
you will notice people from all over the country have different ideas of what to do with their frames. When was the last time you got snowed in? or the snow caked on your truck took two months to thaw out?
AuggieStyle is offline   Reply With Quote
Old 02-13-2008, 07:52 AM   #6
MrGoodpliers
MrGoodpliers's Avatar
I have had good results with GM reconditioning paint. $35 a gallon at your local dealer. Sandblast, open the can, stir, pour it in your paint gun. No priming or mixing and it has a geat satin finish.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-13-2008, 01:45 AM   #7
Hart_Rod
Hart_Rod's Avatar
I POR 15 all my frames, (they are not for show, just don't want them to rust, ) and haven't had any problems. Powdercoating is nice, but a little more pricey. Depends on what your goals are......
R/
Hart_Rod is offline   Reply With Quote
Old 02-13-2008, 03:31 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just remeber por 15 is not uv resistant you will need to clear over it or it will turn foggy..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-13-2008, 03:47 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Here's a thread on POR-15 where I posted some of my observations after doing my chassis....
http://67-72chevytrucks.com/vboard/s...ghlight=por-15
LockDoc
Leon
Old 02-13-2008, 03:48 AM   #10
Hart_Rod
Hart_Rod's Avatar
Can you repost the link, it's not working. Well, at least not for me, .
Old 02-13-2008, 03:49 AM   #11
estig70
estig70's Avatar
Linky no Worky
estig70 is offline   Reply With Quote
Old 02-13-2008, 03:50 AM   #12
LockDoc
LockDoc's Avatar
Done. I noticed that when I tested it.... Thanks.
LockDoc
Leon
Old 02-13-2008, 04:42 AM   #13
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
If you want something that will hold up well, and is cheap, and you mentioned matt finish- use John Deere Blitz Black paint. Google it (looks very appealing). It says it easy to touch up too; the one thing powder coat can’t do……
I think it like $17 a quart. I found this the other day searching JD lamps for my Land Cruiser and it defiantly has my attention!
Hope this helps.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-13-2008, 03:07 PM   #14
LockDoc
LockDoc's Avatar
Hope this helps.
s/t
A friend of mine painted his '50 Chevy with Blitz Black and so far it's holding up great......
LockDoc
Leon
Old 02-13-2008, 10:28 PM   #15
Sport/Truck
Sierra Grande Club
LockDoc
I must admit it looks appealing…..There are lots of pictures on the link on my second post of old Hot Rods and there’s a 50’s Chevy too. Wonder if it’s his?
s/t
Old 02-13-2008, 04:53 AM   #16
Blue'72
Skinned knuckles
Blue'72's Avatar
What about Hammerite? I painted the back half of my longbed frame with it a while ago. It's pretty tough and covers any rust well. The only reason I'm not using it now is because the short frame I'm doing is really clean and I don't need to cover any perfections with the hammered texture.
I'm using Rustoleum Professional in the spray can now. The area I cleaned and painted the other day held up really well to the laquer thinner that I used to wipe the frame down when I finally finished cleaning it.
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 02-13-2008, 04:55 AM   #17
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Definately Por-15 chassis black. Looks good and will never rust again.
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 02-13-2008, 05:16 AM   #18
earl87gta
earl87gta's Avatar
I was going to give this stuff a try http://www.nomorerust.com/ Msgross used it on his biuld check it out here . http://67-72chevytrucks.com/vboard/s...=242910&page=3
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-13-2008, 06:14 AM   #19
Ace in the hole
Used the pm industries coating system on mine too and am very happy with it.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 02-13-2008, 05:43 AM   #20
jwcardy
I will be using Rust Bullet when i tear my truck down to the frame....
-wes
jwcardy is offline   Reply With Quote
Old 02-13-2008, 05:48 AM   #21
shifty
Questionable
shifty's Avatar
Here is a post on Rust Bullet, since it seems to be pretty obscure:
http://67-72chevytrucks.com/vboard/s...&postcount=113
Old 02-13-2008, 11:15 AM   #22
Sport/Truck
Sierra Grande Club
I definitely like the rust bullet. I’ve used POR15 and don’t like it so much. There is a ton of prep work for the stuff too. Although I haven’t done any touch up, it seems like it would be a pain.
I have to admit that the JD paint looked like it would be easy to use. Tractors aren’t generally babied either. Here is some good info about with pictures…. http://crankshaftcoalition.com/wiki/...tz_Black_paint
s/t
Old 02-13-2008, 12:27 PM   #23
Primered_69
Primered_69's Avatar
Go to tractor Supply and buy their Rusty Metal primer and their Low Gloss Black Tractor Paint (add the hardener) and you get a real good result. In my opinion.
Here are some of my truck doing this.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 02-13-2008, 12:29 PM   #24
Primered_69
Close up: Was put on with foam brush and flowed out real good
Old 02-13-2008, 12:30 PM   #25
Primered_69
Notice in the picture above it looks cloudy because my garage is real dusty.
It looks real clean when brushed off
