Old 02-13-2008, 01:15 PM   #1
Jerry Jones
Happy Camper
Jerry Jones's Avatar
72 spindles on a 69
Well my cousin (member El Jay)'s computer is down and is in the process of getting a new one. He asked me to ask the gurus here because he was sitting in one of his two peekups listening to the radio in his driveway, when a feller drove up in his a '72. He said that he had another '72 on his property that he has parted out everything that he needs and wanted to know if El Jay wanted a set of '72 spindles for his '69, I searched but everything came back "drop spindles".
Long story short (too late ), what would he need to know and what else would he need to purchase to make this happen. Any input would be most awsome dudes.
Thanx
JJ
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 02-13-2008, 07:04 PM   #2
JimKshortstep4x4
Re: 72 spindles on a 69
The upper ball joints have to be replaced and the tie rods used from the 72. I cannot think of anything else that is needed but if changing to discs, using the whole cross member assembly from the 72 is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-13-2008, 08:12 PM   #3
69rut
You will need to use the upper and lower ball joints from the donor truck, but they will bolt/press in the the '69 control arms. The tie rod ends are the same, but the tie rod (threaded part) on the 71-72's is larger in diameter.
trailers are for boats
69rut is offline   Reply With Quote
Old 02-13-2008, 11:13 PM   #4
70C10Step
70C10Step's Avatar
I am doing the same swap and I pulled all my parts off my 72 donor truck. Ordered new ball joints from ECE....
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 02-13-2008, 11:54 PM   #5
Jerry Jones
Happy Camper
Great guys, this is what he needed. I will pass it on tonight. Then I may have to have a look @ the guys leftovers for myself.
Old 02-14-2008, 12:08 AM   #6
killer71
killer71's Avatar
i have a set of freshly powder coated spindles off of killer if things fall through
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 02-14-2008, 02:13 AM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
You also have to trim the steering stop on the 72 spindles, but it's doable. About the tie-rod ends, you will need the whole tie-rod form the 72. The drum brake tie-rod ends are different, and 72 ends will not work with the drum brake inners. I found that out the hard way.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-14-2008, 05:07 AM   #8
70C10Step
70C10Step's Avatar
Does anybody have a picture of trimming the steering stop.
All Toys:
Old 02-19-2008, 01:35 AM   #9
Jerry Jones
Happy Camper
That would be a big help too!
Old 02-20-2008, 03:53 AM   #10
Bus Ted Knuckle
Son of a gun
Jerry, this is what I did. So far it is working fine. This picture is from the rear of the passenger side spindle. Trim along the red line.
BEATERS ARE NEATER
Old 02-20-2008, 08:30 AM   #11
Jerry Jones
Happy Camper
Thanx BTK, you da man.
