67 front clip ?
mine has a 69 front clip on it.i know the difference in the hood and grills.but other than the side marker lights are the fenders,inner fender,and core support the same.im going junkin tomorrow so would just like to know 100%.
Re: 67 front clip ?
no there are quite a few subtle differences, the 67 fenders are the same as 68 and all years of gmc the wheel wells i belive are the same and the core support is 67-68 69-70 and 71-72 so look for a 67-68 core support and 67-68 fenders or 67-72 gmc fenders but 67 is the only year without side markersbut if you cant find 67s and its really important that you dont have side markers then u can allways shave the side markers
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Re: 67 front clip ?
I'm thinking if you drill out the spot welds on the GMC headlight buckets and remove them, the core support is the same as a 67-68, If the H/L openings are in the correct location and the mounting pad holes are the same dia. you could use a GMC core support in place of a 67-68. I dont have one of each at the moment to verify this, can anybody add to this ?????
Insert Title Here
Re: 67 front clip ?
gmc has little headlights, i doubt they would be the same
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
1972 Chevrolet SWB
Re: 67 front clip ?
You can drill out the 4 headlight bucket on the GMC core support and a normal headlight attaching point for singles is below it BUT there are a few small holes for the headlight mount needed drilled(off memory) .......I had a GMC frt clip I was going to use at one time but found a complete Chevy 68 clip so I never used the GMC one but did notice all the differences that could be changed if used on a Chevy.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
Re: 67 front clip ?
thanks i believe mine still has 67 core in it.cause the bucket are screwed into it and it just dont look right.but what about the fender are they all the same except for the marker lights.
