02-15-2008, 07:18 AM | #1 |
Ccsb 1-ton 4x4
hi my name is jason, i'm new here. i just bought a 1980 1ton 4x4 cab and chassis. after some closer inspecting i found some pretty thin spots on the frame. so i have decided to pull the drivetrain and use it for a different project. i also just picked up a crew cab on a rolling chassis. my hope is to build a crew cab short bed. i want to run 37" rubber with minimal lift. so here's the basic list
dana 60 front, 14 bolt rear, 52" front springs, 63" rear springs w/shackle flip, opened up fenderwells, 37-12.50-17 procomp extreme at's, looking at about 2"-3" of lift. this could take a while as the weather is pretty bad up here in maine this time of year, but i hope to have it drivable by summer |
02-15-2008, 06:40 PM | #2 |
Next!
Re: Ccsb 1-ton 4x4
Welcome! Do you have pics of these? I have a 83 K30 dually I'm "restoring", more like "reviving", using the frame from a 84 K30 CD30903 ambulance. Frame probably has more issues than yours. This Pennsylvania salt is a killer! Let us know how your adventure turns out. good Luck.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
02-15-2008, 10:51 PM | #3 |
Re: Ccsb 1-ton 4x4
Where are y'all getting these crew cab frames on the cheap? I've been looking all over for one near me, but can't seem to touch a bare one for less than 500, much less, a roller.
Jason, are you moving the Dana/14 combo over to your new frame, or sticking with what it came with? Are you working outdoors? If so, I feel your pain... I'm doing the same thing at the moment. It sucks when you drop a socket in the snow...
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels Who needs a car when they make crew cab trucks? |
02-16-2008, 09:57 AM | #4 |
Re: Ccsb 1-ton 4x4
yes i am moving the dana60/14bolt over to the crew cab. and unfortunately i am working outside. my truck won't fit in my garage...i need to build a bigger one. thats a project for another year.
02-19-2008, 04:16 AM | #5 |
Re: Ccsb 1-ton 4x4
a buddy of mine has a 91 suburban with a fuel injected 350, 4l60, and a sweet interior. i'm going to buy it, and use the engine because it is injected, and i will probably use the transmission as well. the cool thing is that i will be able to have a/c. i can't wait to have this truck done.
89 2wd crew converted to shortbed 4wd, cummins swap (in progress), 63" rears w/shackle flip, 52" fronts, hp dana 60 front w/ 35spline outers/ high steer, van width 14 bolt rear w/ dana 60 calipers, brackets, rotors, 4.56, and detroit. |
02-19-2008, 11:38 AM | #6 |
Sb 400 club
Re: Ccsb 1-ton 4x4
Welcome and cool to see some one closer on here. Sounds like a cool project.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
