Old 02-18-2008, 12:53 AM   #1
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I'm sure someone else has had this happen
I was driving my truck in the rain today and noticed it is dripping water on the floor. It is dripping from both drivers and pasengers side from under the dash. I have a new windshield and gasket installed.
So where is it coming from?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-18-2008, 01:13 AM   #2
cdowns
cdowns's Avatar
Re: I'm sure someone else has had this happen
could be the windshield// could be the sealer in the rain gutters is dried out // could be your cowl vent seal not sealing
Old 02-18-2008, 02:07 AM   #3
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Same here. My leaks didn't start until I had the windshield replaced. I had found that the water is coming in through the gaskets at the lower corners.
The older gasket is not as pliable, thus not conforming to the shape as well.
I should have opted for the new gasket!
mtndewmaniac66 is offline   Reply With Quote
Old 02-18-2008, 01:14 AM   #4
SCOTI
SCOTI's Avatar
Check the wiring gutter that runs along the top of the firewall in the engine compartment. It's a common area for rust because of debris that gets caught in the 'channel' holds moisture.
If that looks good, verify that the windsheild seals are sealing properly. Use a flashlight inside the cab under the dash & look while someone sprays all around the cab area.
Another common area for rust is the vent doors in the kick-panels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-18-2008, 01:19 AM   #5
chrislehr
Engine n00b
chrislehr's Avatar
antenna hole on my right side
chrislehr is offline   Reply With Quote
Old 02-18-2008, 01:30 AM   #6
HavinSomeFun
I was thinking, when water goes in the cowl vents. Where is it supposed to drain? the truck doesnt have any rust to speak of and I want to keep it that way.
Old 02-18-2008, 01:45 AM   #7
hyarbour
Splashing up through the kick panel vent?
hyarbour is offline   Reply With Quote
Old 02-18-2008, 02:12 AM   #8
Premium72
Premium72's Avatar
check the cowl an the wire harness chanel in the engine compartment. hell get the hose out start spray'n and see when an where it starts leaking. good luck
Premium72 is offline   Reply With Quote
Old 02-18-2008, 03:18 AM   #9
pro street 70
pro street 70's Avatar
try using soapy water with wash mit .put water on truck with truck running with blower on high you will see bubbles were leak is @ you can wash the truck after you find the leak.
1970 chevy short step blown 355
pro street 70 is offline   Reply With Quote
Old 02-18-2008, 04:19 AM   #10
wibilly
wibilly's Avatar
check your wiper moter gasket
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-18-2008, 04:23 AM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If the drains for the cowl vents are clogged you might get water thru them.It is unlikely you would have it dripping from the dash though.It would most likely run down the kick panels.It is possible for it to dripto the top of the vent doors and that might look like it was coming from the dash.Best bet is to take a buddy to the car wash.Climb in upside down with a flash light and have him spray away.You should be able to locate exactly where it's coming in.Other than that i would check the weather seals at the top of the door.It might come in and run onto the dash and drip.Also the seals for various things on the firewall could cause it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-18-2008, 04:34 AM   #12
jay6891
Car Knocker
jay6891's Avatar
You mean it rained up there in Little Rock today? My guess would be the rain gutter seam sealer is cracked. Getting in between the outer skin and the inner head liner above the windsheild and running down the A pillers and then hitting the lip on the bottom of the dash and running from there dripping everytime you turn. Will also fill up your brand new glove box insert and make you poke a drain hole in it. No wait thats my truck... my bad.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 02-18-2008, 04:34 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
every truck (and burb) I've owned leaks under the cowl vent. Some one posted a photo here recently of the dried up and cracked seam sealer that is probably the problem.
Old 02-18-2008, 04:53 AM   #14
cameeks
Long Fleet Club
cameeks's Avatar
Same here inside the cowling area above the glove box the seam sealer is crap now and there is a little rust there.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 02-18-2008, 07:09 AM   #15
HavinSomeFun
Thanks for all the ideas. On the pass side it looks like it is coming in from above the glove box and running down the back of it. I bet it is that "new" windshield leaking in and running down. I will try the other ideas when its not raining.
If anyone runs across the photo Longhorn Man is talking about let me know.
Old 02-18-2008, 07:49 AM   #16
tcb-1
Nothing to see here.....
tcb-1's Avatar
yep, my vote for dried seam sealer. found my leak by tracing the dusty water streak marks on the cowl, inside the truck.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-18-2008, 09:43 AM   #17
HavinSomeFun
sounds like a fun fix....
Old 02-18-2008, 09:13 PM   #18
stope4
Wait, you replaced the windshield and windshield gasket and now it's leaking. I wonder where it's coming from?
stope4 is offline   Reply With Quote
Old 02-18-2008, 09:19 PM   #19
franko72
Franko72
franko72's Avatar
happened to me a while back. I felt my left leg getting wet as I was driving in the rain. I checked the gutter along the top of the cab. The sealer was dry and cracked in places. I took my index finger and put a small amount of silicone along the gutter. Never had any more problems.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 02-18-2008, 09:39 PM   #20
HavinSomeFun
It is probably all of the above. This truck was parked in a shed for 15 or so years. I have only owned for a few months and yesterday was the first drive in the rain. I have no doubt it the new windshield, possibly small amount from rain gutter and who knows where else. If it is parked I will see 2 or 3 drops on the floor, when I am driving it down the road it just about pours on the floor on both sides.
Old 02-18-2008, 11:38 PM   #21
The seam sealer in the topgutter drys and the cowl air passage has sealed seams,too.But,either one can rust out as well.Especially the cowl area,even in Arizona.Leaves clog it up and holds moisture.
