02-21-2008, 05:21 AM | #1 |
6 lug disc brakes
What is the best way to put front disc brakes on my 68? Ride height will not change. I want to keep it 6 lug. Some one suggested changing to a 73/87 front cross member to reduce rebuild cost. Will the after market rotors fit? Sounds like a lot of work. Thanks.
02-21-2008, 05:31 AM | #2 |
Old Skool Club
Re: 6 lug disc brakes
Welcome to the board, from Central Arkansas.
I have 6-lug discs on my truck, using Early Classic Enterprises components. There are no stock 6-lug disc rotors that are factory for 2 wheel drive. What ECE manufactures and sells uses stock Delco/GM parts off the shelf, like calipers, etc. If you go with a 5-lug setup (later, for instance) the stock (71-up) rotors will go onto the spindles. If you want to keep 6-lug, and you want to convert to disc brakes, you will have to make a decision as to whose system you want to use. If you elect to utilize a 73-87 crossmember to get a disc brake setup, you'll still have to find a supplier to get the rotors for 6-lugs. There are other suppliers than ECE, some of them are "on the board". Look for the red screen names, to locate the vendors.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-21-2008, 06:27 AM | #3 |
1972 Chevrolet SWB
There are about 1/2 dozen manufacturers for a spindle conversion for your truck that dont lower it any,and will just convert your 6 lug drum set up to a 6lug disc set up like ChevLoRay stated.
check the board vendors like GMC Paul and others to see what they have.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-21-2008, 07:40 AM | #4 |
Chevy One
Look in the FAQ truck tech!
Chevy One 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
