02-22-2008, 06:20 AM | #1 |
Driver side door lock....anyone?
Im looking for anyone that has put a door lock on their 47-54 chevy pickup, i have a 48 with the external lock(not in the handle) and want a lock on the driver side. I thought there was a kit or something for this but couldnt find anything, i even searched. Pop in with any info positive or negative. Thanks fellas!!
03-08-2008, 07:20 AM | #2 |
Re: Driver side door lock....anyone?
ttt
03-08-2008, 10:19 AM | #3 |
why not just use a remote entry lock setup? my 98' grand cherokee had that setup and seems to work smooth. bet you could rob a setup off something in the boneyard. that way you could keep the key on passener side in case of dead battery or malfunction.
03-08-2008, 10:20 AM | #4 |
i dont have power locks....sooo wouldnt that make it kinda hard?? i dunno, i just want a lock on that side and not to have to custom make something
03-09-2008, 01:34 AM | #5 |
I think you can use any 47-at least 59 guts out of the handle. I have key locks on both side and there keyed the same as the ignition and glove box.
Is that a camaro bed on that? |
03-09-2008, 01:34 AM | #6 |
Oh, and you can find new kits anywhere or get them out of a deluxe cab.
03-09-2008, 02:49 AM | #7 |
47 to 52 does not have a push button handel.
03-09-2008, 09:53 PM | #8 |
It may be difficult if you want to keep you stock handles. I'm going PL to fix it as my '54 doors were ditched to have a 1 piece window.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
03-10-2008, 05:30 AM | #9 |
I also wanted a drivers side key lock and installed the lock before I discovered the latch on the drivers side is different from the passenger side and is missing some important parts for the key lock to work. I had previously done this on a 56 F++d pickup and it worked fine. I don't know of any kits for this modification. I've purchased an extra passenger latch and plan to see if I can add the needed parts to the drivers latch. Just haven't had the time to deal with it lately. Let us know if you discover a kit.
