Old 02-23-2008, 12:27 AM   #1
kxnomore
kxnomore's Avatar
Help... Late for Work- truck won't turn over...
Hey guys. My truck won't do anything to turn over. The lights and everything like that works just fine, but the engine won't even try to turn over. I'm thinking it's either a bad ignition switch, or a loose or broken wire down at the solenoid. There's a rat's nest under the dash and under the hood.
Does anyone know which wires I can jump at the ignition switch to see if that will kick it over? And if that doesn't do it, which wires do I jump down at the Solenoid? Is it the outer wire to the block, or the one nearest the block?
Thanks in advance.
kxnomore is offline   Reply With Quote
Old 02-23-2008, 12:30 AM   #2
Jim_PA
Re: Help... Late for Work- truck won't turn over...
Yeah, you can just put a screwdriver between the 2 posts on the solenoid. Make sure it's in neutral ;-)
Jim_PA is offline   Reply With Quote
Old 02-23-2008, 12:34 AM   #3
kxnomore
kxnomore's Avatar
Thanks Jim,
which two posts? There's 3 down there, and I don't want to blow anything up. At least not yet...
Old 02-23-2008, 12:42 AM   #4
The Big Green
Did you get it? Its the one on the starter that has the big postive cable coming from your batter and the little wires coming from your ignition, it will have a little 5/16 nut and should be right behind that postive cable on your starter. If you got it let us know what it was.
The Big Green is offline   Reply With Quote
Old 02-23-2008, 02:37 AM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
A pics worth a thousand words....LOL. Hope this helps.
Also if its an automatic check the safety switch on the column its where the purple wire from the starter comes from.
sneakysnake is offline   Reply With Quote
Old 02-23-2008, 12:34 AM   #6
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
wires to jump= purple and thick pink or red. ignition on in park.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 02-23-2008, 04:00 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
did you try moving the shifter a little with the key turned?
Old 02-23-2008, 07:46 AM   #8
kxnomore
kxnomore's Avatar
Hey guys,
I'm back from work now and can give an update. It was the neutral safety switch. I didn't figure it out until I got back after jumping the solenoid the first time, and then after driving it around a bit it started right up, but then wouldn't start again after parking. But then after pulling hard on the shifter, it would start again.
Thanks again for all your help, it really did save me from trouble at work!
