Old 10-23-2002, 10:43 PM   #1
>X<
registered IWATA user
>X<'s Avatar
Engine is tapping bad, but not all the time, how do i adjust rockers?
my engine (350 pontiac with at least 200 thou miles on it) taps real bad at 50 or over, does this all the time, but now it taps when i take a right turn, not a right angle tun, but a gradual right curve, i taps very bad, but not on left, so that meant it must just be one side, also when i get on it, it taps bad right before it shifts, i've never taken off the valve covers before, but would like to learn how to adjust valves, since it might be this, i guess. what do i lok for to be wrong when i take the covers of? thanks, sean
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 10-23-2002, 10:54 PM   #2
bigjimzlll
bigjimzlll's Avatar
Hi...it dosen't sound like lifters rattling to me...have you checked your oil?????? if its a little low then when you turn the oil pick up wont be in the oil...then the tappets will make noise... I hate to even mention the fact that might be a rod a knockin...check the oil first...if its low try alittle 20-50w in it
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-23-2002, 11:00 PM   #3
Hooter
My other Love
Hooter's Avatar
well if you want to know how to adjust the valves here is how i do it. I will start the motor throw on the custom valve cover i made so i can have access to the rocker bolts and not have oil get all over the place. 1. Back off the valve until it starts going clickity click 2 slowly tighten it until it gets quiet 3 tighten it another 1/4 turn
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-23-2002, 11:08 PM   #4
Jwill41
Jwill41's Avatar
i have always used 3/4 turn total but 1/4 at a time.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 10-24-2002, 07:34 AM   #5
JimKshortstep4x4
Talking
I adjust valves as Hooter does, but I install the little clips on the rockers to keep the oil from squirting over the top of the cut off valve cover. I have done the 1/4 turn tight as Hooter does for a lot of years and it works well over time.
The rattle you hear could be lifters or possibly rods. The lifters are the first to rattle when oil pressure drops off. If the engine oil is ok, it is possible that the pickup screen is set too high in the pan or has dropped off. When you go around a curve the oil can move away from the oil pump pickup and what you describe sounds like a loss of oil pressure.
Jim
Old 10-24-2002, 07:51 AM   #6
meathead95
computer illiterate
meathead95's Avatar
I would check the exhaust manifolds real quick before I took the valve covers off. you could have a loose manifold. maybe when you go around a curve your truck twist makes it leak a little more my v-8 s-10 leaks like you said all the time I am constantly tightening the headers on it. I may be wrong but its worth a shot.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 10-24-2002, 08:45 AM   #7
Frank_Zeller
Frank_Zeller's Avatar
The stock Pontiac rocker arm set up is non adjustable. Just torque the nuts to around 25 foot pounds. You can convert to chevy bb studs and polylocks if you have screw in studs to make the valve train adjustable. Also try running plus one quart of oil to see if the problem goes away. I do this on my 455 to insure I have enough oil at high rpm. No ill effects.
I would be interested in you frame to motor mounts if you ever deside to go back to a Chevy motor.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 10-24-2002, 03:20 PM   #8
>X<
>X<'s Avatar
bigjim- i check the oil weekly, so i dont think its that, but it might be the pickup thing, but why does it only do it on right turns? if it is this wouldnt it do it on both right and left? thanks, sean
meathead95-it cant be the bolts because if i let off the gas it stops, so its motor related, thanks for guess tough
Frank Zeller- i'll take he cocvers off today if i get off work. my motor mounts look homade, and i'm selling my truck when i finish painting it, but if i o decide to put eth 454 in that truck, i'll save your name for the mounts, but i dont think there worth anything. i can takesome pics if yo uwant though
Old 10-24-2002, 03:24 PM   #9
meathead95
computer illiterate
meathead95's Avatar
when you let out of the gas on my s-10 it gets alot quieter too. less exhaust pressure, less exhaust leak. just a thought though. your description sounded just like my sh*tty headers on my s-10
72 2wd blazer
72 swb 4x4
Old 10-24-2002, 03:56 PM   #10
>X<
>X<'s Avatar
i'm gonna go outside right now and check ex. manifold bolts, and check rockers later, truck wouldnt start by the way, been having problems with battery and alternator, i think alernator isnt bog enougt for battery. thanks man
