Old 02-25-2008, 07:53 AM   #1
kevinr1970
Fuel tank switch '86 vs. '87
I recently bought a fuel tank switch to use on my '86 truck. It turns out the switch I bought is for '87 and newer.
On the switch one of the four "poles" has a "bump".
The only difference I can see is that the "bump" is on a different "pole" on the two switches.
My question is, if I can remove the bump on the newer switch will it work on the older truck?
I have to assume there is something different about the switches or why would they make them different?
But if one will work in place of the other I will just figure out a way to remove the bump.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-25-2008, 01:15 PM   #2
kevinr1970
Re: Fuel tank switch '86 vs. '87
Oops, meant to attach this picture.
2000 Tahoe Limited
Old 02-25-2008, 09:04 PM   #3
blu87
blu87's Avatar
I think probably the same, bumps notwithstanding. To keep it simple, I would ohm meter each terminal and match them to one another. You're checking for s/w terminal continuity, not ohm resistance. I just changed my 87 s/w out and the orig one looks like yours on the left.
Gene
blu87 is offline   Reply With Quote
Old 02-27-2008, 01:17 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I would check them, they require different PN', but I don't know if it makes a difference. The 87 does have electric pumps...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
