02-25-2008, 07:53 AM | #1 |
truck wont start
everything is fine but for some reason the engine itself wont turn over, it was running 4-5 days ago and a couple days ago i tried to adjust the neutral safety switch but i couldnt get to the bolts and i got tired of trying so i tapped it with a hammer to move it so did i kill the switch or what???
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
02-25-2008, 08:28 AM | #2 |
Re: truck wont start
I would say you either killed it or knocked it out of alignment.
02-25-2008, 08:44 AM | #3 |
thanks
02-25-2008, 07:37 PM | #4 |
Dave's not here, man
You could try unplugging it and jumping it with a piece of wire. If it start you've found your culprit.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
02-25-2008, 08:45 PM | #5 |
Sierra Grande Club
try to move the shift lever while trying to start it. Even try in the neutral position that way you can go forward & backward to hit the
contacts. Then maybe you'll will be able to figure out what direction its out of adjustment? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-25-2008, 11:40 PM | #6 |
To The Levy
maybe your hammer wasnt big enough. grab a bigger hammer next time.....
LOL ... just be a lil sarcastic.... |
