Old 02-25-2008, 03:32 PM   #1
cochino12
It followed me home?
cochino12's Avatar
heater/vent vacuum tube routing
can someone take some pictures of their ac vacuum line routing for me? I'm having some problems with no defrost in my 85. thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-26-2008, 07:20 PM   #2
cochino12
cochino12's Avatar
Re: heater/vent vacuum tube routing
anyone?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-26-2008, 08:57 PM   #3
LBJ
It's too late to take pics because I have already done the fix. The defrost problem on my 77 was due to the vac line INSIDE the plenum assembly under the dash being rotted away. You have to stand on your head to get to it. I used some silicone fuel tubing to replace that line with since it's something you don't want to do again. There is a vacuum actuator INSIDE that pulls the door closed for the defrost and releases for the other functions. Once you get a light in there, you can see where the actuator is and plan your attack from there. Some diassembly of the plenum chamber is required. I used some long nosed forceps to attach the line to the actuator. The other lines are pretty straight forward to get to. Start at the carb and go to the little accumulator ball on the firewall first. Then, the line goes thru the firewall to the various actuators. Some of the lines are plastic with little flexible nibs of clear tubing on the ends. The plastic line usually does not wear out, but it might get cut or crimped and need replacing. There is also a vacuum line going to the actuator right in front of and under the windshield wipers on the passenger side (under that plastic screen). Check that too for loss of vacuum.
My system now works like brand new, including fixing the problem of feeling like the heater is on all the time. I am very satisfied now.
LBJ is offline   Reply With Quote
Old 02-26-2008, 09:03 PM   #4
cochino12
cochino12's Avatar
thanks for the help, there are no lines hooked to the accumulator ball now hopfully that is the only problem. Where do I hook it up on the carb?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-27-2008, 04:49 AM   #5
75gmck25
The vacuum ball is connected to manifold vacuum. On an SBC you should just use a T to connct it to back of the intake manifold on the passenger side. The other part of the T will be the vacuum line to the transmission, if you have one.
Bruce
75gmck25 is offline   Reply With Quote
Old 02-28-2008, 02:43 AM   #6
LBJ
Having the hose missing might also explain any roughness or missing of the engine at idle - vacuum leak at the carb base. Assuming that is the case. I would still check the line that "powers" the vacuum actuator for the defrost door for being in poor condition. It's something that you will probably only have to fix one last time if you use silicone tubing.
