02-26-2008, 07:14 AM | #1 |
door differences
I know i have read about this before....................my truck has one original door for it's 69 cab... the other door is from a 71 i believe and it has a dimple and a hole adjacent to the wind wing area on the inside of the door top edge kinda right below the wing arera. Can this hole and dimple be filled??
Thank you
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
02-26-2008, 03:03 PM | #2 |
Re: door differences
The door with the hole at the vent window is a 72. If you fill the hole you will need to make sure of the brace in the area, (look in your 69 door as it will have a flat piece of sheet metal that connects the two halves of the door).
67-71 doors had cracking problems in the connection allowing the door to spread so the screw was added in 72 to cure the problem. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
