pics of 5/5 drop please
Im new here, can any body post some pic of their drops with info such as drop,rim width,b/s, tire size. have a 86 silverado swb going with 5/5 drop stock rallys 15x8. 275/60 rear 255/60 front. planning on a flip kit(no c-notch) 3inch spindles 2 inch coils (hear i have to do some grinding on the lower control arms) does this sound feasable? i will appreciate any help!
Cruzzzn' Vet
Re: pics of 5/5 drop please
This is my 83
![]() ![]() 4/5 drop(2 cut coils and flip kit) 15x9 shoes 4"BS 275/50/R15 TA's ![]() |
![]() Join Date: Oct 2006
nice !!! what size tires/wheels ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Right in front of you.
Mine is about a 5/6 or so....flipped with no notch.....it's close to the bumpstops, which are aftermarket.
Stock 15x7 and 8 Rallys, 235/60-15's and 275/60-15's.... ![]()
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
so the flip kit is like 5 inches ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada ![]() MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 |
Yeah...the store bought kits are "generally" 5", it depends on the leaf spring packs....
But flipping a rear is so easy making your own "kit", that you can go lower if needed, just weld on new perches and use blocks (I always thought those U shaped "blocks" in flip kits were cheesy)....but anything over 5" needs a notch...honestly, mine could use a notch...it'd have a bit more clearance, esp. with a load...
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A Last edited by 69BBsuburban; 02-28-2008 at 12:52 AM. |
Insert Title Here
![]() That truck sits perfect... right on the tires.. nice
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
OL BLUU
![]() Join Date: Mar 2004
Here's mine with a 5/6 drop... running 17's back then.
#9 | ||
What size wheel/tire were you running?
Anthony |
This was my stepdad's truck....when he was killed, my mom gave me the truck.....so I'm not certain the exact drop specs.... I do know it is a combo of springs and spindles. Probably 3" springs and 2" spindles, as there are no modifications or grinding of the A-arms or calipers, which is normally needed when 3" spindles are used with factory Rallys.....
I had an '80 with 3" drop spindles, and this truck is much lower.
Heres Mine, She Has A 5/7 Drop. Flip Out Back With Drop Shackles And Drop Spindles/springs Up Front
#12 | |||
Anthony |
it says under maol's pic his tires size 275/50/r15 wheels are 15x9's
OL BLUU
Here's your info man:
Front: 17x8.5 with 255/60/17 Goodyear GTII tires 4" Back spacing Rear: 17x9.5 with 275/60/17 Goodyear GTII tires 5.5" Back spacing Thanks, Anthony |
#15 |
It Is What It Is,,,,
![]() 5/5 drop here ![]()
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
#16 |
Wide n'Low
![]() Join Date: Jan 2007
Mine was a 5/5 before I decided to go air.
Tires at the time of the picture were 255/50/15 I think.. ![]()
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#17 |
Until Seventy Times Seven
Good-looking 78, Twisted...
Not to go OT, but is the installation of the Procharger complete? If so, got any pics?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#18 |
Wide n'Low
Thanks,
Almost complete, working to finish some exhaust before the inital run-in. I want to put some miles on the motor before I run the Procharger. Been a bit side tracked getting my Blazer projects underway. All in good time.. With the weather getting better, I had better get on it! ![]()
#19 | ||
![]() Thanks for the response.
#20 |
Here is my 84 with 5/6 and 20/s
#21 |
6.0 powered square
I just lowered mine 5" in the with 3" spindles and 2" coils and I accidentally order the spindles for the bigger brakes since I figured the Id# says its has the heavy duty package and rear has big drums, but the good thing is I now have new brakes, but the stance looks the same when it was lowerd 3inchs I guess since I havent drove the truck yet they havent setteld
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#22 |
man all those trucks sit so cool !
I'm worried about my headers scraping every if i'm that low. plus mine is a long bed so i wonder if my rear bumped and tow hitch will scrap ?
#23 |
![]() Join Date: Mar 2006
Flip kit, 2" springs and 2.5" spindles here for a 4.5/5 drop. Ive got plenty of room between my axle and the bumpstops. Tires are 275/60/15 all around.
Twisted...that is a FINE looking truck you have there!
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#24 |
This is my longbed dropped with 2,5" spindles and 2" springs and a flipkit!
She rolls on 10x15 eagle alloys with 265/50 and 295/50 Bfgs! more pics in my webalbum!
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red Last edited by moneyeater; 02-29-2008 at 12:28 AM. |
#25 |
Flat Black, & Chrome!
