![]() Join Date: Nov 2007
I bought what some fool swore to be a Chevy 350 motor for my 67 project .
I looked up the numbers 18488572 and cannot find out anything about this motor. I guess for $100 bucks I should of just bought some beer and my headache would of been about the same, Any help would be great. Thanks
72 C20 Longbed 05 1500 Z71 |
Addicted to Chevy
Re: Block ID
i believe that is a pontiac block... dont quote me on that though
Addicted to Chevy
Re: Block ID
what color is it painted?
Still livin the "dream" in '54
Re: Block ID
Well, I am not sure about this but I came across a French site that says something about it being a Pontiac 350.
I don't read french well though. Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
Son of a gun
Re: Block ID
Most Pontiac block numbers start with a 5. Some do start with a 9 or a 4, and a couple start with 3's. I can't recall any starting with 1. If it is a Pontiac, and it was made after 68, the cubic inch displacement will be cast into the driver side of the block just in front of the front freeze plug. Olds motor numbers start with 3, so rules that out. Buick maybe?
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 02-27-2008 at 09:42 AM. |
![]() Join Date: Feb 2004
Re: Block ID
If I remember correctly the Buick had the distributor in the front of the engine.
All Pontiac blocks have a hydraulic lifter valley pan. The distributor hole is located on the rear deck of the block which allows for the easy intake removal without disturbing the distributor 4th digit reveals that it should have been made in either 1978 or 1968 (look for the motor mount holes, should be 2 if 68 and 4 if 78) 2 freeze plugs 66 or earlier 3 freeze plugs 67 to 78
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" Last edited by 72armyswbtruck; 02-27-2008 at 02:53 PM. |
Re: Block ID
Isn't the pontiac transmission mounting to the engine different than a chevy?
