Old 02-29-2008, 08:21 AM   #1
jpabberton
madcow
jpabberton's Avatar
Vibrationn at 35-40 MPH
I get a strange vibration between 35-40 MPH when I am accelerating but it stops when I back off the gas pedal. 2001 GMC SWB 2x2 Stepside with auto V6. The front end does not vibrate and the noise stops above 40 MPH. Could it be the drive line? Any suggestions?
1970 SWB 4x4
350 4 speed
Factory AC
jpabberton is offline   Reply With Quote
Old 02-29-2008, 04:53 PM   #2
mothertrucker424
mothertrucker424's Avatar
Re: Vibrationn at 35-40 MPH
balance tires and check for front end play and see if the tires are chopped
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 02-29-2008, 07:22 PM   #3
Huck
Huck's Avatar
Tire balance, tire out of round (belt separation?), bent wheel, front end wear, driveshaft universal joint, ----could be any of the above. Go for the simple first.
Huck is offline   Reply With Quote
Old 03-02-2008, 05:30 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
I had a rear end that had an improper set up and was in dire need of a rebuild that would cause the truck to vibrate while decelerating from highway speeds.
Pyrotechnic is offline   Reply With Quote
Old 03-04-2008, 07:01 AM   #5
DavesRide
DavesRide's Avatar
From your description I would lean towards driveline. U-joints would be my first choice. Pull shaft and fell if joints are binding. If joints are smooth then I might ask you if the tune up and or plug wires has ever been performed (replaced?) Maybe it is misfiring on acceleration.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 03-04-2008, 07:41 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Look at your U-joints first, then look at tires and see if you threw a weight off of abalance spot or have a tire that is demonstrating a busted belt.
Old 03-12-2008, 05:18 AM   #7
jpabberton
madcow
jpabberton's Avatar
I just put on 4 new tires and wheels off of a 2008 GMC Yukon. The issue is still there. I suspect the DL. I will check that out next.
Thanks for the help!
1970 SWB 4x4
350 4 speed
Factory AC
