![]() Join Date: Feb 2008
Widest wheel width on 71 fleetside
I am looking for information from others on the widest wheel you have installed on the rear. My measurements indicate I should be able to mount a 12 inch wide rim with 7 1/2 inch backspacing with 15 in wide tires but I am looking for advice before committing. Thank you
The LuvShack Garage
Re: Widest wheel width on 71 fleetside
![]() ![]() Is it gonna be lowered? Airbags or coil? (Airbags tend to give side to side play) I know 10" is no problem at all, for 12" you may need to widen the rear tubs.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 03-02-2008 at 06:06 AM. |
That's an important question, yes I am bagging it. I already have the tubs and have cut the bed for maximum fit.
A guy with a truck
I was planning nearly the exact same setup. You should have room to spare if you widen the tubs to the framerails...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
At one time, I had 15x14" custom back-spaced steelies w/a stock length 67/8 12-bolt truck rear (coil suspension). The bumpstop on the outside of the framerail had to go & obviously the tubs were stretched, but it required no frame modifications.
Thank you for your reply
