Old 03-02-2008, 08:05 PM   #1
Big Irish
Big Irish's Avatar
Watts link info
Anyone running a watts link with bags ? Love to know your opinions .
Thanks .
67 short wide
1955 Chevy 2 door Wagon
1967 Short Wide BAGGED Gone to someone else
1953 Shop truck Clipped and Snipped sold
1951 GMC Bagged and patina
Big Irish is offline   Reply With Quote
Old 03-03-2008, 02:54 AM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: Watts linkinfo
Started on mine this week havnt finished it yet.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 03-03-2008, 05:20 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Watts linkinfo
Thanks .
67 short wide
Check out the 67 link in my signature....This was a one off assembly I built for a 14 Bolt Full Floater. The operation of a watt-link is super-precise, with 0 side to side movement at all. Up and down, the axle remained within a 1/64"
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-03-2008, 09:35 AM   #4
Big Irish
Big Irish's Avatar
Re: Watts link info
That's great news . I will lookinto getting one . From what you are saying it should solve my problem without cutting my truck . Any opinons on which one . I have seen the KP one , it is well within my skill set to intall . The crazy thing is the one from Totaly polished is the same money , and yes it is fully polished unit . but welding and some skills I dont have are needed .
The other question is I cant seem to find contact info on the KP site to find out how much clearance i need from my dif to the fuel cell which i have mounted between the rails .
Anyone know /
Thanks again
Old 03-03-2008, 10:05 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Watts link info
The KP unit is a quality product that will bolt-up to the 12-bolt.
I didn't know the TP was the same price....nice piece there too.
Regardless, the watts is the way to go !!!
Let me know if I can be of more assistance.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-04-2008, 02:53 AM   #6
stunna
Re: Watts link info
can someone give me a link to a site that has the info on the watts link. i am interested if it is a true bolt in kit for my 69. thanks
stunna is offline   Reply With Quote
Old 03-04-2008, 03:18 AM   #7
jlaird
jlaird's Avatar
Re: Watts link info
kp components
totally polished
speedwaymotors Some guys have used this one, but you'll have to do some fabricating to make it fit.
jlaird is offline   Reply With Quote
Old 03-04-2008, 07:40 AM   #8
Big Irish
Big Irish's Avatar
Re: Watts link info
Do you have a watts link in your own truck ?
Old 03-04-2008, 03:35 AM   #9
hotrodhomi
hotrodhomi's Avatar
Re: Watts link info
I put the KP link in my blazer this weekend. I had to modify the crossmember in front of the gas tank. and extend the flexible brake line. crossmember mod should not be needed on a truck from what I've been told.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-04-2008, 03:37 AM   #10
hotrodhomi
hotrodhomi's Avatar
Re: Watts link info
FYI, KP link is not totally bolt on if your frame is not boxed. You need to weld a plate on the frame (box it in) on each side.
'66 impala ht
Old 03-04-2008, 05:51 AM   #11
jwcardy
Re: Watts link info
thats good to know...
-wes
jwcardy is offline   Reply With Quote
Old 03-04-2008, 07:39 AM   #12
Big Irish
Big Irish's Avatar
Re: Watts link info
Did installing that KP setup totally eliminate your side to movement . I have 1 " or less tire clearance at ride hieght .
Old 03-04-2008, 07:50 AM   #13
hotrodhomi
hotrodhomi's Avatar
Re: Watts link info
I'm still in the process of finishing the install. I need to do some more measurements and adjusting the link bars, but I expect to see no side to side movement. The theory of the watts link is zero side to side movement. I'll let you know after next weekend what the actual results are. I'm optimistic.
When I called about the adjustable panhard bar they said that there was only 1/2 inch of side to side movement throughout the travel. The watts should be much less if any.
'66 impala ht
Old 03-04-2008, 07:56 AM   #14
Big Irish
Big Irish's Avatar
Re: Watts link info
thanks for the response , good luck next weekend . How much was the kit ?
Old 03-04-2008, 08:19 AM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Watts link info
Like I mentioned before....there is NO side to movement at all.....
Absolutely none !!
CHeck out this F-150 I did a while ago...
This thing has 23" wheels, with less than 1/8" clearance on the side where the fender radius start to drop down. Bagged, with custom cantilevers and watts link
No rubbing...constant axle locating thru ENTIRE suspension travel...
Sorry for the Ford pics....not my truck...not my style of doors...but thats what the customer wanted...money is money !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-04-2008, 08:33 AM   #16
Slmd92DIME
Slmd92DIME's Avatar
Re: Watts link info
In the new Sport Truck they have a article about how to properly set up a watts link and panhard bar... I referred to it a couple times. Like at half travel the "pivot arm" should be just a little off center and the watts link bars should be horizontal with the ground... I didnt know that.. I dunno it was very helpful to me though
My Build Thread
Old 03-04-2008, 09:07 AM   #17
hotrodhomi
hotrodhomi's Avatar
Re: Watts link info
Good to know. What month is that?
'66 impala ht
Old 03-04-2008, 09:16 AM   #18
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Watts link info
That is correct. I found that out when doing the 14 bolt. If the center is straight up and down, then it'll run out of travel and pull to the side. This was happening with just the bag travel (8")....you would need a little more offset with a canti set-up.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-04-2008, 06:57 PM   #19
Big Irish
Big Irish's Avatar
Re: Watts link info
Chief thanks for the clearity . Do you believe with my adjustable panhard bar that I would be safe for clearance . Like i said I have nearly an inch on both sides at one point in the suspension travel . But maybe I am just not adjusting it properly .I am going to order the KP unit if need be but would appreciate your opinion before spending that $ .
I am going to get that Sport Truck Article right away and see if that gives me some info as well .
Thanks again .
Old 03-04-2008, 08:04 PM   #20
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Watts link info
If you have a whole inch on both sides, then I think you would be fine with just a panhard bar.
Center it a ride height, and away you go.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-04-2008, 08:26 PM   #21
Big Irish
Big Irish's Avatar
Re: Watts link info
As soon as the snow is gone that will be my plan , thanks again . I hope you dont mind if I keep your contact for future info .
Old 03-04-2008, 03:52 PM   #22
Slmd92DIME
Slmd92DIME's Avatar
Re: Watts link info
April '08... Green and blue fullsize GMC on the cover and a chick in a red shirt.
My Build Thread
Old 03-11-2008, 12:56 AM   #23
hotrodhomi
hotrodhomi's Avatar
Re: Watts link info
Watts link installed and adjusted. Zero side to side movement from full air to aired out. It's a nice piece. Did you order one?
'66 impala ht
Old 03-11-2008, 02:19 AM   #24
SCOTI
SCOTI's Avatar
Re: Watts link info
How about some pics??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-11-2008, 06:30 AM   #25
Big Irish
Big Irish's Avatar
Re: Watts link info
Contacted , KP .They are moving there facility right now . 30 days or so they should have one .
Clint contacted me , sounds like a great guy with allot of knowledge .
I would like nothing better than to post some pics . 2 issues one is we are in 2 ft of snow since yesterday .
And i need to figure out how to do it .
i hope to take the truck next weekend to Performance Worls , which is Canada 's largest show . If I make it I will take lots of pics and and figure out how to post them .
It's the least I can do , after all the help and support .
