03-03-2008, 07:22 AM | #1 |
Fuel Pump Question and Issue---need help!!!
Im going to replace my 305 with a 350 unfortunately I cant use a mechanical fuel pump on that block so I bought a Holley Blue Pump. Now, I know how to hook the fuel pump and the regulator but after looking under the truck I found the valve and found out that the tanks have return lines. I will not be using the right side tank so that will be pulled out. Im just going to run the drivers side tank. Just to make sure before I start doing anything..... I am going to run it straight from tank into the fuel pump and bypass the valve, going into the regulator then to the carb and also plugging the return line. Am I correct? Let me know your advise and suggestions
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
03-03-2008, 09:33 AM | #2 |
Ephesians 2:8
Re: Fuel Pump Question and Issue---need help!!!
I used a Holey Mechanical pump, no return line on it, I just plugged the return line, didn't have any issues with it. Should be fine.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
03-03-2008, 09:55 AM | #3 |
hello,,running a 1999 5.7 out of a caddy escalade in my 76,, electric fuel pump, no return line,,run's fine..
03-03-2008, 10:03 AM | #4 |
Ephesians 2:8
Carbed I assume??
03-03-2008, 10:22 AM | #5 |
hello,,yes,carbed...
03-03-2008, 10:26 AM | #6 |
Ephesians 2:8
sweet, bet it runs good!
03-05-2008, 12:25 AM | #7 |
Right turn Clyde
Why dont you want to run a return line?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
