Old 03-04-2008, 01:47 AM   #1
Tim64
Tim64's Avatar
Starter question
Hey Guys,
Had lots of discussion on which flex plate to use for my 700r4 swap. If I remember right, if the starter bolt holes are inline on the flange it's a 153 tooth flex plate, if the bolt holes are at an angle it's a 168 tooth plate. Here is a picture of my flange. 3 bolt holes tell me I could go either way. Is this right? I just want to make sure.
Thanks,
Tim64 is offline   Reply With Quote
Old 03-04-2008, 02:38 AM   #2
greg64
greg64's Avatar
Re: Starter question
Hi Tim,
Perfect pictures. You can see that all 3 holes are tapped, so you can use either the 153 (inline) or 168 (angled) ring gear. It also clearly shows that your existing starter mounted to the bellhousing (same setup as I have).
So, now you need a ring gear with the correct pattern for the torque convertor and for the crank flange (pre 86 SB).
Also, don't forget to find a pair of the correct starter bolts, because you probably don't have these right now (different than bellhousing mount bolts). And, it seems there are a couple of different lengths in these bolts too (my 64 uses shorter bolts than my 77).
Keep on pluggin...
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
