03-04-2008, 08:07 PM | #1 |
amp wiring ?
Does the "amp rem" wire out the back of the head unit go to the "p conn" on my amp? If not what are each of those for? I want to be sure before smoking something up! THANKS
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
03-04-2008, 09:45 PM | #2 |
Re: amp wiring ?
'amp rem' is the wire coming out of the head unit that turns on the amplifier. Not sure what 'p conn' is. What is the brand and model number of your amplifier?
- Greg |
03-04-2008, 10:48 PM | #3 |
Love That '69
Re: amp wiring ?
Like 454HO said, the 'amp rem' wire coming from the head unit is the wire that turns on the amplifier when you turn your deck on. On your amp there should be 3 connections beside each other. Ground (GND), Power (B+), and your Remote (REM).
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates Last edited by Classic69; 03-04-2008 at 10:49 PM. |
