Old 03-05-2008, 02:37 AM   #1
slug
slug's Avatar
oil cooler
anyone here running a aftermarket oil cooler?? if so, what brand, where did you get it and how do you like it??
slug is offline   Reply With Quote
Old 03-05-2008, 05:10 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: oil cooler
Engine oil or tranny?
I run tranny coolers in both my Jimmy and 83 truck.
I mounted it differently after removing the front. Works great!
I bought the biggest cooler the parts stores had A 24000 GVW cooler! I needed a cooler to cool this beast.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-05-2008, 09:14 AM   #3
slug
slug's Avatar
Re: oil cooler
for engine oil
Old 03-05-2008, 09:28 AM   #4
gchemist
gchemist's Avatar
Re: oil cooler
I just replaced the oil cooler lines on my 96 Jimmy. The factory adaptor uses the radiator as a cooler.
Check with www.summitracing.com
Part number : BMM-70270
A kit containing a filter relocation kit is best. The key to avoid leaks replacing the o-rings and gaskets on the adaptor. The adaptor screws into the block. The filter then screws into the adaptor.
