03-05-2008, 11:29 PM | #1 |
Transgo Shift Kit
I heard shift kits are a must in an auto trans. I was wondering which one of the two transgo kits I should get for my Th 400. I got a 427 under the hood and 3.08 gears. I am wondering what the main difference is on the two different kits they offer? Also, how exactly do they work and is Transgo for sure the best way to go? I have heard about B&M as well. I am not concerned with comfort just performance.
Thought I would ask the board about this cuz everyone is always helpful Last edited by michael23v; 03-05-2008 at 11:29 PM. |
03-05-2008, 11:35 PM | #2 |
More Cowbell....
Re: Transgo Shift Kit
I had a Transgo kit in my TH350. Not sure which one it was. Plenty of snatch between shifts. I loved it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
03-05-2008, 11:43 PM | #3 |
Skinned knuckles
My first rebuild was on a TH400 and the guy that rebuilt it swore by Transgo. According to him, much better than B&M. I don't know, but I had like a stage 1 in it and I liked it!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
03-05-2008, 11:48 PM | #4 |
i beleive transgo is the same shift kit that Gearstar performance uses too. They are known for building high quality automatic trannys.
03-06-2008, 04:09 AM | #5 |
ok thanks for the advice
03-06-2008, 05:15 AM | #6 |
i put a trans-go kit in my vette. teice the money as a b&m but glad i spent the money for the trans-go
common sense isn't so common anymore |
03-06-2008, 05:40 AM | #7 |
Speed Limit = Floorboard
Transgo is the best, be weary of "transco" not the same company or products. There are those who don't believe in shift kits, do your research, I believe Vettevet has some articles on 700r4's and one on shift kits that applies to all autotrans. The main point is that in an auto trans to complete a shift, a clutch pack or band must release "before" another engages, the problem with a shift kit is that sometimes for a micro second during this process both are engaged effectivly causing a transbrake for a slight second. That said reliefs in the seperator plate to allow faster disengagement of a friction surface is never a bad thing, theres a difference in a fast firm shift, and a crash shift. Not trying to say anything bad about shift kits, but its not exactly a fool proof deal, like many things they should be taken with a grain of salt.
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
03-06-2008, 06:28 AM | #8 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-06-2008, 07:22 AM | #9 |
Transgo all the way. B&M shift to hard.
03-06-2008, 07:34 AM | #10 |
So educate me...Transgo will give you a firm shift but not a "snap your neck" type shift? I remember a shssift kit on a car that I use to own and it would "jerk" you neck when changing gears...which I did not like. Maybe an old age thing?? On a 400 auto.---what would the advantages for using the Transgo? Thanks in advance.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-06-2008, 08:22 AM | #11 |
Active Member
Shift kits consist of nothing more than intermediate plates & gaskets.
Not much in the way of rocket science. When you install the kit they will give you a couple of choices regarding what check balls to leave out and what place to drill the holes in the intermediate plates. This determines how hard your shifts will be. If you buy a level 3 kit it will give you an additional intermediate plate and you will take out almost all of the check balls and they might give you an adjustable pressure regulator to adjust shift timing. B&M, Transgo, Fairbanks, TCI, Hughes all make good kits
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
03-07-2008, 06:32 AM | #12 |
Chevy nut
I have used Transgo and never had a problem with it. I have also used B&M kits too. Just go with your gut feeling.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
