Old 03-07-2008, 10:55 AM   #1
shifty
Questionable
shifty's Avatar
Question Rear diff covers, panhard stud removal
I know, if you've seen one, you've seen a thousand rear diff covers. I'm assuming on my '68, I can literally use any rear diff cover out there as long as it is 8.875"? Probably the only thing I'm doing to my rear axle housing for dress-up is throwing a chrome rear diff cover on, and I see most are around $20-25, and come with gasket + bolts. Just thought i'd ask anyway.
On a related note, how do I remove the big, bulky panhard bar mount on the top corner of diff? I can't really see any clear way to do this, there is a rubberized coating on the back side, I think? Nothing given in the Chilton/Haynes/whatever manual I have. I thought about just cutting the rear diff housing on either side and pulling it that way (I'll never use it again), but didn't want to eat up any more cutoff wheel than needed.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-07-2008, 06:58 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Rear diff covers, panhard stud removal
Here's one I made for a 14bolt....
This particular one was to mount the pivot for a Watts:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-07-2008, 07:38 PM   #3
Shane
Shane's Avatar
can't remember how I got the panhard mount out/off ... but it's possible cause mine is gone. give me till this weekend to get back over to the shop and i'll look at it a bit closer, going from memory here and could be wrong, but I think it's a bolt on affair.
p.s. you'll regret using one of those chrome diff covers ... i haven't seen one yet that didn't eventually leak ...
Shane is offline   Reply With Quote
Old 03-07-2008, 11:41 PM   #4
XXL
Seņor Member
XXL's Avatar
I too don't remember what I had to do to get that mount off... but brute force tends to be my method, and I didn't break the loop in doing it. I seem to recall that it's a large "washer" with a stud that's threaded on both ends-- one for the Panhard bar and one to mount it to the rearend. I'm not much help on that one... but, like Shane says, the chrome diff cover will leak. After cutting up my stock cover to build a Watts link mount, then scrapping the Watts and sticking with the ECE Super Track bar I already had, I needed a quick cover... so I bought one of the $20 on ebay. I've been throwing gaskets and silicone at it ever since
XXL is offline   Reply With Quote
Old 03-07-2008, 08:35 PM   #5
shifty
Questionable
shifty's Avatar
So, it sounds like powdercoating the original one is the better way to go, eh?
My new axles should be here in 10-14 days. Once they get here, I plan on emptying the pumpkin (probably never had the fluid changed), taking some brake cleaner or kerosene to the guts (per other suggestions I searched), then tossing a better looking cover on.
For the panhard mount, it looks like there is a rubberized coating on the back side of it, and it almost looks like it could be a nut. I didn't try to cut it off though to see what's up w/it.
I kinda want to keep the provision there - no telling what it could ever be good for, but ...
Old 03-07-2008, 09:34 PM   #6
SCOTI
SCOTI's Avatar
I tried everything I could think of but mine wouldn't budge. In my case, I was simply removing it for cosmetic reasons. Since I'm using a 'suoer track-bar' type set-up & I'm skilled in the art of disassembly & dicing things up, I opted to whack the threaded portion off & smooth out what remained.
Now the 'boss' that's cast into the housing has a nice 'plug' vs. an open hole.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2008, 04:05 AM   #7
slammed1
1972 Chevrolet SWB
slammed1's Avatar
The panhard bar mount on my rear diff wasnt that hard to remove by using a large hammer after the nut and washer were removed. I left the hole for now but for cleanliness may ground it off later.
The truck 12 bolts us a specifc rear cover as long as you get a cover for a Chevrolet truck 12 bolt your golden......oh,stay away from cheap Taiwan chrome diff covers if you can.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 03-08-2008, 06:14 AM   #8
jlaird
jlaird's Avatar
I just bought a stock rear diff cover from LMC. To my surprise, it was a genuine GM part. Seemed like it was a heavy gauge steel.
jlaird is offline   Reply With Quote
Old 03-08-2008, 09:11 AM   #9
PipsC10
PipsC10's Avatar
I used a mini sledge and knocked out the stud from mine. It seemed as if it was pressed in because it would not budge and then it shot out like a rocket and almost hit my Dads truck that was in the shop. I just picked up another rear end and did the same thing, only this time the stud came out very easily.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
