Old 03-07-2008, 11:12 PM   #1
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Question HEI Tach wire running??
Anyone have any idea where i need to run the Tach wire into the cab?? Is there a factory location that went into the fuse box, or did it just run through a rubber busing in the fire wall??
BTW i'm running a 455 buick HEI in a 69 CST10.
ttt
jayharrell is offline   Reply With Quote
Old 03-07-2008, 11:15 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: HEI Tach wire running??
The factory tach has a double connection on the back of it. The wire off the dizzy ran to the connector then to ground I beleive. It's been awhile since I really looked at it. You may want to wait for a better answer.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-08-2008, 01:30 AM   #3
jayharrell
jayharrell's Avatar
I see how it plugs up, just not sure how it made it into the cab. I guess i can run it through one of the extra plug wholes in the main firewall conector behind the fuse box.
Old 03-08-2008, 02:09 AM   #4
desertPOS
desertPOS's Avatar
I ran mine up into the 'sill' at the top of the firewall and into other wiring I have running through there, then dropped it back down after it made if past the brake master and ran it through a body plug that had another wire running through it (right next to the fuse box). Then just spliced the original connector onto it, lubed the end of the connector with connector grease, and plugged it in. If you REALLY want, I could probably get a picture later, but just run it as clean as you can and you'll be fine...
desertPOS is offline   Reply With Quote
Old 03-08-2008, 04:05 AM   #5
Andy4639
Old member
Andy4639's Avatar
OK I ran mine threw the opening where the old windsheild washer hoses came out. Sorry about that I didn't have a good understanding of what you wanted I guess.
Old 03-08-2008, 05:42 AM   #6
jayharrell
jayharrell's Avatar
NP.. thanks for the info. If the weather clears up i'll see what i mesh together outa everyone and take some pics.
Old 03-08-2008, 04:04 AM   #7
byrd
Union Electrician
byrd's Avatar
there is a gromet near where the factory oil pressure line goes in the cab, that is where the factory tach wire is suppossed to be run...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
