Old 03-09-2008, 11:16 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Few questions
Ok, I have a few questions here
#1 How much can I notch the frame & still be strong enough to haul something around 3-4 thousand pounds ??? (I plan to plate the top / sides & box the inside, & use a piece of 4" 1/4" wall pipe) I just need to know how deep I can make it & still be safe
#2 At what point is it advantageous to flip over the trailing arm mounts ??? (I have a one piece drive shaft, so I don't have a carrier bearing to flip)
#3 What is the optimum angle for my shocks to run at (I am building new shock mounts)
#4 Last but not least, if you were building a long panhard bar to run from the frame to the passenger side trailing arm would you use rubber bushing syle ends or heim joints ???
Thanks, Matt
P.S. I do not want a step notch, just something I can build that is hopefully deeper than a bolt in notch
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-10-2008, 05:38 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Few questions
ttt
Sinister
Killer
Old 03-10-2008, 10:20 AM   #3
SCOTI
SCOTI's Avatar
Re: Few questions
I wouldn't go more than 2/3 of the height of the frame (3" max).
Necessary or advantageous? My 68 was dropped enough that the rear axle tube was inside the c-notch @ ride height. I never experienced drivetrain vibration or had u-joint related failure.
I fabricated new upper shock mounts @ just duplicated what the factory engineered as far as shock angles. I figure it worked for this long, it must be real close to optimum.
Option 'C' . . ...... Urethane. The benefit of heims w/o the noise.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
