Old 05-04-2002, 04:19 PM   #1
Beast388
Suburbans RULE!
Beast388's Avatar
Question Question for 4X4 guys and gals
I am in the market for new tie rod ends. In the LMC catalog, the picture in catalog CB.22 on page 97....it shows the tie rod ends pointing up. Or in other words the grease zerks are pointing toward the ground. On my Suburban, it is the opposite. My zerks point upward and the nuts on the tie rod ends are on the bottom of the knuckles. How are everyone elses set up? Zerks up or zerks down?
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 05-04-2002, 04:28 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Talking
Nuts on the bottom, zerks on top on my K25.
1970 GMC K25 Custom
Chesapeake, VA
My 70 GMCor Webshots http://community.webshots.com/user/70gmc
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-04-2002, 04:29 PM   #3
Blue_71
Bloo
Blue_71's Avatar
Post
my grease things go out the sides and the nut is on bottom
1971 3/4 ton 4x4 355SB SM465 NP205 dana 44 front eaton corp FF rear, 4:10 gears
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-04-2002, 05:31 PM   #4
swede413
swede413's Avatar
Post
My zerks are up on my brub and my blazer
70 burb 4/4 6^ 35BFGS 4on floor 70 blazer 350 3on tree needs tlc
98 GMC 3/4 ton 4x4 5 speed manual
swede413 is offline   Reply With Quote
Old 05-04-2002, 05:39 PM   #5
Vince M
Vince M's Avatar
Post
Nuts on the bottom..Zerks on the top.
Orlando,FL
72 Chevy 4x4 3/4T CustomCamper w/SB 406
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 05-04-2002, 08:23 PM   #6
Blue_71
Bloo
Blue_71's Avatar
Post
somethings going on here, everybodys zerks on top, and mien go out the sides, whats p with this?!?!?!
1989 Chevy K2500
Old 05-04-2002, 10:29 PM   #7
MJN
MJN's Avatar
Post
Some were on the side and on top. It depends on who you got them from. Kind of a visible difference between brands I guess. As long as the grease fittings are on top or above the steering arm on the axle and the nut on the bottom your okay.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-05-2002, 04:25 AM   #8
Duallie
Duallie's Avatar
Post
If I understand your question, you're referring to the tierod between steering knuckles.
I personally have never noticed, but I've heard of a rough rule of thumb for determining 10-bolt/dana44 differences at a glance, and that is studs up for dana44 and studs down for 10-bolt. It all depends on the source of the knuckles themselves.
Don't do like my dad did this winter. He rebuilt his front axle and mixed parts up to get the best ones, got it all assembled, and found the knuckles he happened to install had different direction tierod holes!
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 05-05-2002, 06:30 PM   #9
Vince M
Vince M's Avatar
Post
Mine has the Dana 44 and the zerks are out the sides. I said they were on top..but I meant on top with respect to the stud only. Hope that's al clear now that I've muddied it up a bit.
Orlando,FL
Old 05-06-2002, 11:58 AM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Post
Nuts on bottom, zerks on the side. I'd say the illustrations in LMC must be wrong.
'69 K-5 Blazer - 350/TH350, 6" lift, 35" tires
Bothell, WA
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-06-2002, 01:21 PM   #11
Beast388
Suburbans RULE!
Beast388's Avatar
Talking
Ya.....LMC has to be wrong. That is why I ordered them from Autozone...a little more expensive but easier to return if they are wrong. I even looked at my buddy's '74 GMC K20 and his are the same as ours.
71 GMC Suburban 4X4
The "Beast"
--Ben
71 GMC Suburban 4X4
The "Beast"
