76 Grill/Headlamps on 84 Nose
I have a 76 GMC the cab and fenders are rotted bad. I picked up an 84 with a good cab and nose but I like the look of the round headlamps better. Can I put the 76 grill and headlamps in the 84 nose? I also want to use the 76 dash in the truck can I just swap the pad? Ed
Chris
Re: 76 Grill/Headlamps on 84 Nose
I think the pad would work but the front end would take alot of work. You'd have to fab up alot of things. Best bet maybe be buy some 73-80 fenders and put them on.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
I thought the dash would work but was unsure of the grille headlamp swap. I only need a left hand fender and inner fender wells for the 76 nose and I found some new repo's stuff locally for $150 for all. How does the repo stuff fit? Ed
#5 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If it is the cheap stuff, you can make it fit (see above question), but it will take some work. Otherwise I have found Goodmarks improved stamping to be a close fit based on a friend truck that got some from me.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
