Pat
power steering box
i am going to put power steering on my truck
when i turn my power steering box by hand it feels kind stiff and a little gritty, compared to my manual box witch spins easy and feels smooth. what should a power steering box feel like and will mine be fine? thanx pat |
Hollister Road Co.
Re: power steering box
it should be easier than your manual box. It may have air in it or not enough fluid or its bad along with the pump
Pat
the pump isnt connnected its not even on the truck. so i turned the part that bolts onto the steering. it was harder to turn and felt a bit gritty
Rice Killing 101
flush it see if it helps at all might have some dirt or if worse case metal :|
![]() ![]() Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread ![]() |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
It will be very hard to turn without having fluid going to it. But it should not feel gritty. If you are very careful, you can take that top cover off. Just try not to move the adjusting screw, and if you do, count the turns and put it right back where it was. That way you can inspect the inside and see what is causing it to feel gritty. Flush it out with some clean PS fluid and reseal the top. Hook up the hoses and give it a spin!
Good luck!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
