Old 03-13-2008, 09:30 PM   #1
eastcoastcivil
Anyone have under cab pics?
I am working on my 68 GMC and the bottom of the cab just ain't right. I will post a pic of what the PO did to my truck (its aaaaaallll wrong). For now I was wondering if anyone has any pics of the under side of there cab to share so I can see what should be there and what the PO has added. You won't beleive these pics I am gonna post) Thanks
If your not living for something, your dieing for nothing...
eastcoastcivil is offline   Reply With Quote
Old 03-13-2008, 09:46 PM   #2
shifty
Questionable
shifty's Avatar
Re: Anyone have under cab pics?
Searching the forum for "cab flip", I found this: http://67-72chevytrucks.com/vboard/s...d.php?t=180110
Kevin @ LFD designs also makes a tip/flip cab mount setup, and wherever his thread is around here, it has pictures of under-cab also. I think the pics in that last thread might help you out, though. If not, searching for terms like "supports" (to find "cab supports" threads) might help greatly. Don't use the "Google" search feature up near the top. Use the one on the right-hand side just above the 67-73 forum thread list.
Note - the search feature WILL NOT return results on 3-letter search terms, so searching for "cab" won't return anything.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-13-2008, 10:33 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I saved this pic that somebody posted a while back. Hope it helps...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
