03-14-2008, 11:05 PM | #1 |
Return Line Through Fuel Gauge Unit?
It seems to me, I read about someone who used the vapor line fitting on the fuel sending unit for a retun line on a TBI conversion. Right now, I have a '69 with the single feed line fitting on the fuel level float unit. I need to replace that unit and was thinking of getting one for the later models that have the vapor line fitting.
I'm not doing a TBI conversion right now, but since I'm looking ahead to when I do so I'd need to just cap off the line for a time. Any problems there? Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
03-15-2008, 02:03 AM | #2 |
Active Member
Re: Return Line Through Fuel Gauge Unit?
I did exactly what you stated and have had 0 problems with the set-up.
1971 SWB SOLD
03-16-2008, 09:45 AM | #3 |
i also used it for a diesel fuel return line to tank. no problems.
I BELIEVE IN JOHN 3:16 |
03-16-2008, 09:52 AM | #4 |
I made my own return in the same spot where the later stock vapor line would be and it's working like a champ.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
07-28-2008, 12:33 PM | #5 | |
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
