03-15-2008, 07:41 PM | #1 |
It followed me home?
stock height 3/4 with 285's, pics?
I realize all of these trucks sit just a bit different height wise but I was curious if anyone has 285's on 6-8" rims and if they rub or not? 285's are a little smaller than 33"s so I dont think I will have a problem, anyone have pics? thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-15-2008, 08:55 PM | #2 |
Re: stock height 3/4 with 285's, pics?
I believe that TexasJeff's brown 3/4 ton 2 wheel drive is running 285/75/16's .Search for his truck . Frank
Born and proudly residing in a Red State ! |
03-15-2008, 09:35 PM | #3 |
Here is a Pic of my stock height 3/4 2WD with 285/50/20s they measure around 31" tall. The wheels are 20x9 all the way around.
03-15-2008, 09:42 PM | #4 |
Don't Crush em Restore em
Frank is right, here are some pics. Mine don't rub at all, from lock to lock. Even over uneven ground I have never had any problem with rubbing.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
03-16-2008, 05:10 AM | #5 |
texasjeff, thanks for the pics. I thought they would fit fine just wanted some to be sure before I spent the money on some tires
03-16-2008, 05:55 AM | #6 |
One thing to keep in mind before you buy will be the wheels themselves . The wheels on that slick brown truck are very offset and probably help with the rubbing issue . The same tire on an eight inch wide wheel might be a different story . Unless it has a lot of backspacing it will place it further out and may contact the fender while turning . Just a thought . Frank
03-16-2008, 09:39 PM | #7 |
Right turn Clyde
I have 285/75/16 on stock 16x7 rims in the rear no problem. Mine are 33in tall. Not sure what the stock backspace is.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
