Should an I6 be level?
Hi,
Just got my 700R4 and I6 together. I am mounting it in the truck but the engine is not level. The front of the engine is 1 inch higher than the back. Is this a big deal? How unlevel before it a problem? Thanks Buck |
Junior Member
Re: Should an I6 be level?
I think my 250 L6 sits that way. I'll double check tomorrow.
Junior Member
Buck,
While I didn't actually measure it, when laying a level on my valve cover of my 250, the front is all of 1-1/2" taller than the rear on stock mounts. Bob |
I believe it's the carb that you want level (floats and all that...) not necessarily the engine.
ColoradoMelons.com |
No they don't sit level. Only the intake manifold should be level.
l6 Performance Parts http://www.merchantamerica.com/chevy...ex.php?ba=home BOTHERS http://www.brotherstrucks.com/ LMC http://www.lmctruck.com/ Dash LEDs http://www.whitegauges.net/index.php |
I am so glad I'm lucky. The intake manifold is almost level. I can drop the trans about 1/2" and it should be good. Thanks for the help.
Buck |
Hey Buck,
I'm going to be doing the same thing this Friday. Did you run into any problems, or concerns you could share with me before I start? Thanks, Tim |
