03-17-2008, 07:06 AM | #1 |
The difference of a vortec
These might seem like silly questions but I'm going to ask them anyway. What is the main difference between regular and vortec heads? Are the heads the only difference in a "vortec" engine? Can you use vortec heads on a regular block? If so, how? Will a regular intake manifold fit vortec heads? If not why? Is there already a thread that explains all of this? Sorry in advance.
-Scott- |
03-17-2008, 07:12 AM | #2 |
Re: The difference of a vortec
Thats a good question!!
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
03-17-2008, 07:35 AM | #3 |
Vortec engines require a manifold specifically for vortec's, relating to how the intake bolts on to the heads. I think you can use vortec heads on an old style block, but not 100% sure. Vortec engines use electronic fuel pumps and have no provision in the block for a traditional fuel pump.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
03-17-2008, 07:39 AM | #4 |
wat is the difference between a regular chevy engine and a vortech engine anyway?
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
03-17-2008, 07:46 AM | #5 |
The Vortec Head can be bolted on to any old school block however a special intake is required to allow a carb but also have the vortec bolt pattern GM offers one and so does summit but are offered in alum only....the Vortec head has a 64cc Combustion chamber and swirl ports which allows them to flow much better then the best old school chevy heads including the 202 heads, i have not used them but have friends that do and i can tell you this they are the best bang for your buck head on the market,
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB, "some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno Last edited by retselgerg; 03-17-2008 at 07:54 AM. |
03-17-2008, 08:13 AM | #6 |
Long Fleet Club
Where the intake bolts to the heads it is at a wider pitch then the regular intakes
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
03-17-2008, 08:32 AM | #7 |
I have a radical idea!
They are also drilled at different angle. One thing to keep if mind if building a hot engine with Vortec heads that if you use a camshaft with more than .480" lift, the stock springs will coil bind. .488" is actually the dimensional limit, but with variances in tolerances, .480" lift is really pushing it. Most street profiles are no where near that lift, but keep it in mind if you building a street/strip engine with a radical cam. Here is a flow test comparing the Vortecs to old double humps (462's)are some aftermarket performance heads. They flow better up to .500" lift than any head in the test. They are capable of some very good HP numbers.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-17-2008 at 08:32 AM. |
03-17-2008, 08:14 AM | #8 |
Awesome info, thanks
03-17-2008, 08:22 AM | #9 |
I have a 89 Suburban long block I am using, and I swapped on Vortec heads, using GM head bolts for a Vortec motor, along with GM gaskets and an Edelbrock votec pattern intake with a 650 carb.
Vortec blocks also have a roller camshaft fyi. The roller cam and head design are the main diffs. Also have a 1 peice main seal. They also use a platic timming cover, but I believe a early style metal cover will also work.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 Last edited by BP68; 03-17-2008 at 08:23 AM. |
03-18-2008, 04:36 AM | #10 | |
Yes, you have to pull the collar off to get it to fit. That is a 99 5.7L Vortec. With an old school timing cover on it. You also lose two bolts in the cover, as the block's not tapped for it. It's also running a GM performance intake for TBI. They (GMPP and Edelbrock each), make an intake for TBI or Carb. 96-99 is the cross over years, where some parts will work. We happened to add a 400 crank to make this one a 383. Also got some head work to the Vortec heads. The later model Vortecs get much different, with coil packs instead of distributors and a bunch of whole other fun items. Last edited by FormerMember; 03-18-2008 at 04:37 AM. |
03-17-2008, 09:00 AM | #11 |
good info!! considering them for a later 383 IROC-Z Project
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB, "some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno |
03-17-2008, 09:20 AM | #12 |
They work great on 383's. I ran a set for a while on my 82 Z28, before I stepped up to 230cc Dart Iron Eagles. I forget to mention that reason they bind is that the valve guide boss is high on these heads and it has to be machined to run a bigger cam cam than .480 which is an easy job for any automotive machine shop. I was running 12.40's @ 109 MPH with the Vortecs and a fairly mild hyd roller on a 9.3 : 1 CR 383 with a 650 Demon carb, TH350 with a 2400 stall and 3.73 gears in my '82 Z28 before I got more racdical with 383.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-17-2008, 08:14 PM | #13 |
gm also made an intake for a tbi set up for the vortex engine,i put one on my truck works great
03-18-2008, 03:37 AM | #14 |
A good number of the vortec engines have roller cams, as well.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
03-18-2008, 04:20 AM | #15 |
Vortecs are a great value. I bought a new set from a dealer for $399, and another set at a salvage yard for $200. They have heart shaped combstion chambers and redesigned ports which make for a much better flowing head than the general's previous designs. If you use factory gaskets, be aware that they are only torqued to something like 15lb-ft and will fail if you overtorque them. I like the fel pro gaskets as the match the ports a little better. Self-aligning rocker arms are also required.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
03-18-2008, 04:45 AM | #16 |
So let's make this a FAQ. There are 3 types of aftermarket Vortec heads as below. The Vortec design has increased "swirl" for improved combustion and flow that's equal to or better than entry-level aftermarket heads - especially in the mid-range which is so important for a street engine.
[EDIT based on 67_C-30's comments]
03-18-2008, 06:46 AM | #17 | |
Pretty good list except the HP/CID numbers are off. Stock Vortecs are capable of producing 420+ on 350CID engine which is exactly 1.2 HP/CID. This has been documented buy numerous magazine buildups, and I have done it myself on two different occasions.
03-18-2008, 07:07 AM | #18 |
Agreed. The motor in that Blazer dyno'd at 413 hp and 453t lbs of torque. We could've squeezed more out of it, but elected to keep it a bit tamer. Granted, it's a 383 with port and polish work, but stock GM castings, but does prove to be more than 1HP per CI.
03-18-2008, 07:08 AM | #19 | |
Again, all IMHO. I've built 6 engines now with the stock Vortecs and love 'em - but I don't recommend them for power levels much over what I noted. Willing to edit my post with some add'l background Last edited by Billla; 03-18-2008 at 07:20 AM. |
03-18-2008, 07:42 AM | #20 |
These are the only two I can find on online but I have several more here in mags from 5 -6 years ago that were in Super Chevy and Car Craft. Forget dyno bumbers, I had a set of STOCK Vortec heads on a .030" over 4 valve relief hypereutectic flattop 350, with COMP .474" lift 284/288 duration hyd roller with a Edelbrock Performer PRM intake, a 650 Demon carb with a TH350, 2400 B&M Holeshot stall and 3.73 gears in a 3360# (race weight) '82 Z28 and I ran 12.40's at 109. You do the math. According to NHRA's formula, it takes at 340 RWHP to push a 3360# car to 109 MPH trap speed. Figure the 20% drivetrain that is typical with an automatic transmisson, and the puts you at 425 HP at the crank. Either way you slice it, that is way above 1HP/CID.
The tests and literature I've seen show that the Vortecs flow around 240 cfm at .500". The chart above shows 239/147. http://www.popularhotrodding.com/eng...ine/index.html http://www.chevyhiperformance.com/te...ild/index.html
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-18-2008 at 07:43 AM. |
03-18-2008, 08:12 AM | #21 |
Our numbers might differ by a bit, but I'll buy the 1/4 mile numbers (the only real numbers, I agree) and I definitely trust the Popular Hot Rodding guys...CHP, not so much.
So I'll tweak my post - I still think that at these power levels you'd find more power with an aftermarket head than the stock Vortecs...which was the point of my comment - but it's a fair cop I have a tendency to go a bit mild on my cam choices, which is part of the difference. Comment on the tweak and I'll adjust a bit more if needed. All the stock Vortec flow numbers I've seen have been around the numbers i noted - the small-port Bowtie number are closer to what you note. We might have to agree to disagree on that one Last edited by Billla; 03-18-2008 at 08:16 AM. |
03-18-2008, 07:55 AM | #22 |
another common misconception ive seen often, alot of people mistake the 87- and up centerbolt style head for the vortech heads. ive seen this so many times i dont even try and correct people. the vortechs have the 3 little triangles on the front, and the older 80's centerbolt vc style head doesnt
03-18-2008, 08:04 AM | #23 | |
03-18-2008, 08:06 AM | #24 | |
We used to joke around because the 305 TBI heads are casting number 187, which in police code Homicide/DOA!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-18-2008 at 08:07 AM. |
