Old 03-18-2008, 03:38 AM   #1
collin86
tire size vs rake, sportsman s/r radials
ok so i already bought my rear tires they are the mickey thompson sportsman s/r radials 29x18x20. i will have a 20x15 rear wheel, but i dont know what tire size to put up front to make it look proper. i want to do 18" wheels up front. probably an 18x8 or 18x10. below is my tire size options. im just not sure what will give it the best look, i dont want to much rake either. any pictures of a similar tire size package would be helpful. just let me know what you guys think
26X6.00R18LT
26X8.00R18LT
26X10.00R18LT
26X12.00R18LT
28X10.00R18LT
28X12.00R18LT
collin86 is offline   Reply With Quote
Old 03-18-2008, 04:57 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: tire size vs rake, sportsman s/r radials
I would eliminate the 28s, since these tire sizes would give you more tire sidewall as compared to what's in the rear. Proportionally, the 26s would work... probably the 26X10.00R18LT on a 8"-9" wide wheel. In the end, you're end up with a 3" stagger between the fronts and rears. You're 'bably going to have to drop the rear a bit more to make the front look good without imposing a rake. Those rear meats should look .
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 03-18-2008, 08:56 PM   #3
collin86
thats kinda the tire size i was thinking to. the 10" wide should give some good grip on the road as well. i will have 4 link and coilovers in the rear so lowering a bit more is no problem, im thinking around a 5/7 drop should look real good
