Old 03-19-2008, 10:18 PM   #1
johnboyon20s
johnboy's thread
delete
johnboyon20s is offline   Reply With Quote
Old 03-19-2008, 10:24 PM   #2
johnboyon20s
Re: johnboy's thread
my question for the day is
does anybody have info on the older caddy rearends?
like is it the same width as a stock chevy truck rearend?
anybody know a website where i can check into it?
i have heard that the older caddy had a 5x5 with disc brakes
they also have a rear end thats 5x4.75 with drum
i wonder if they offered a 5x4.75 with disc
i would love to run disc rear brakes, the deal is the wheels im running are for a s-10 they are 5x4.75 so this will work great if its the same width i wont have to run adapters
one more ? are the front rotors the same as a truck, could i put the caddy rotors with 5x4.75 pattern on some truck drop spindles?
Old 03-20-2008, 05:38 PM   #3
johnboyon20s
nobody knows any info?
Old 03-20-2008, 06:32 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you are wanting to use S10 wheels on the truck you are going to have to change the whole truck over.
The benefit to the caddy rear ends is they were drilled for 5 on 5 like the trucks. Disc were only available on the HD versions (5 x 5 only)
If you want s10 wheels get the rearend out of an F-body. Of course you still have the front to contend with.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-20-2008, 07:16 PM   #5
johnboyon20s
i already got s-10 wheels, thanks for the reply what year were the fbody? and do ya know if they are same width as truck rearend?
Old 04-16-2008, 06:56 AM   #6
johnboyon20s
heres the link to my pics
Old 04-16-2008, 11:21 PM   #7
slug
slug's Avatar
i would suggest finding a donor truck or suburban so you can get everything you can off of it. is that a short wheel base??
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-17-2008, 07:10 PM   #8
johnboyon20s
its a long bed, im gonna be shortning it, i already have a bed, i pretty much have a whole truck its just in pieces and boxes
Old 06-29-2008, 11:56 PM   #9
johnboyon20s
well i got a little update, got a 3/4 frame thats been bagged im gonna cut it off in the back and put it on my 1/2 ton
keith at Nfamous customs in dallas,tx did the work, custom tribal 2 link bars with tubular bag mount and tube work and watts link, i will clean it up and prolly take it apart and paint and take better pics later on
Old 06-30-2008, 07:43 PM   #10
johnboyon20s
i think i voided the warranty lol
Old 07-01-2008, 02:54 AM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
man, I thought you were scraping the two link...
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-06-2008, 12:57 AM   #12
johnboyon20s
got some progress done today swapped the back halfs out made it a swb , i welded and bolted the frame back together, its not done but it rolls for now heres some pics
Old 07-06-2008, 02:38 AM   #13
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks good.. i like how its a old 3/4 ton frame, or was it a 1 ton...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-06-2008, 11:55 AM   #14
johnboyon20s
i think it was a 3/4 ton , it was a single wheel 4 door long wheel base truck with 350 motor, and my truck is a 1/2 ton long wheel base
Old 07-06-2008, 12:42 PM   #15
f.monroe
f.monroe's Avatar
Looks like a 14 bolt full floater rear so it was probably a 3/4 ton .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-07-2008, 01:12 AM   #16
johnboyon20s
yea im gonna swap it out and put my 1/2 ton rear end, i got the bed cut out and sit it on today
Old 07-08-2008, 12:27 PM   #17
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks good.. i know some of the lincolns had a disk brake rear end to.. not sure on the bolt pattern...the 84 mark VII i had was air ride from the factory, so useing it on a 4 link wouldnt be that hard to do....
Old 07-15-2008, 02:08 AM   #18
johnboyon20s
well i got the front bagged been working on it all weekend on and off, i pancaked the crossmember and i will say its alot of labor and headache so far, but i really didnt wanna z the front end, iwould definately invest in a dropmember if i had the money in my budget, for now im gonna try to make as much of my stock stuff work as possible.
after i get back from heatwave in austin im gonna work on fitting the stock steering back on it.
its late so my pics are dark i will take better pics in the daylight
Old 07-15-2008, 03:16 PM   #19
johnboyon20s
full lift
Old 07-16-2008, 12:50 PM   #20
johnboyon20s
i noticed that the dash is welded in on the top and bolted on the side?
i was wondering if its ok to cut it out and make the dash bolt in? that way i can remove it when i ever need/want to......
Old 07-17-2008, 06:02 PM   #21
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
If you could think of a way to fab it up and make it work, why not?
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-17-2008, 01:44 PM   #22
johnboyon20s
anybody?
Old 07-22-2008, 01:05 PM   #23
johnboyon20s
got the stock steering back on
lays 22s with stock steering
Old 07-22-2008, 02:01 PM   #24
smashingchuck
so you raised the steering as much as you raised the crossmember, right? Other wise it is going to bump steer really badly.
78 Build Thread
4Runner Build
Old 07-23-2008, 01:47 PM   #25
johnboyon20s
well i i was gonna raise it 2 inches, but all i needed was 1 inch to clear everything, and i actually left the passenger side in the stock location, its kinda a trial and error, hopefully it will drive lol
i want it to be safe and work so feel free to let me know what im doin wrong or if something isnt gonna work?
