When this valve in the cowl panel closes, does the inside kick panel vent opens? Thanks, Luis.
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
454 MAKES IT ROAR
Re: A/C air shut off valve
Wow spooky! I was going to post this question as well, I noticed this the other day when I fitted my new vacuum valve under the hood and as you say the door under the cowl closes and the vent kick panel opens....it can't be right, anyone know if this is correct?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-20-2008 at 03:18 AM. |
member #16
![]() Join Date: Dec 1999
Just a guess, but wouldn't that be changing from outside air to inside air? It has to get air from somewhere.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
454 MAKES IT ROAR
Yes the lever on the heater control is set to inside when this happens but when I move the selector lever to outside air the kick panel vent closes again but the vent door under the cowl still remains shut, and all my vacuum valves have been replaced so they are working fine.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
For the coldest AC setting the vent door opens, the water valve closes, and the air door closes on the 70-72 trucks with the two port vacuum switch. Here is a schematic of the two port vacuum switch that I believe you have on your truck. (I can post the three port switch if for some reason your truck has one).
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#6 | |
454 MAKES IT ROAR
eightbanger,
There should be a spring on the door to open it up when the vacuum is off. Here is a pic of the spring, (the upper end of the spring is hooked to the wrong hole in the picture).
Gettin By on Gettin By
Think of it like a Max setting, or recirculate. It just shuts off all out side air and recirculates then air in the cab.
#9 | |
454 MAKES IT ROAR
![]() Quote:
Thanks everyone.
I too am missing this spring. do you know anyone who sells this spring? I'm sure I could use a generic spring if I knew the length and pull strength of the spring. Any idea? I'm considering modifying with a 12V door lock actuator to replace the vacuum.
![]() Join Date: May 2010
Here's a picture of an original spring. It is very "stout". They are almost always missing due to their location and rust. They are not reproduced as far as I know.
Where exactly is the control head vacuum switch (as shown on daigram) located in the truck? Also would a problem with that switch be responsible for allowing outside air to flow in through the A/C vents when moving, but not when stopped, even if the heater/A/C is switched off?
#13 | |
454 MAKES IT ROAR
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-20-2008 at 04:16 AM. |
I am looking for a "Control head Vacuum Switch" that is missing on the back of my heater control. Cany anyone help me with a part number or resource to purchase one? Thanks, Bob
#15 |
![]() Join Date: Jun 2000
#16 |
I don't have that spring, either! NEVER HEARD OF IT!! Thanks so much!
#17 |
Thanks for posting the pics. I went and checked and my spring is missing. Off the hardware store I go
#18 |
subscribed
#19 |
Great info. Thanks!
#20 |
I like this thread. It is very informative. Subscribed for future reference
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#21 |
I learned something new today about the presence of this spring and the fact that I don't have one ! Thank You for the info !!!!
Tom |
#22 |
Old member
If your not a puriest the best mod you can do is close off that cowl vent completely! Seal it up tight and never close the passenger side kick panel vent again.
I'm not joking either. Your AC will be cooler and you want have all these problems with it anymore.One of the best mods I ever did, ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#23 |
#24 |
Can someone post a pick of the inside door vacuum switch configuration? Also it has a spring too?
#25 |
![]() Join Date: Feb 2009
It works like this. https://scontent-sjc3-1.xx.fbcdn.net...rg&oe=65560872
Short answer is that's operated by selecting INSIDE on your controller. That closes the upper cowl air door, and opens the kick panel door. INSIDE also shuts water circulation to the heater core via the water valve, for 1971-72. OUTSIDE does the opposite, or really, anytime that lever is not on INSIDE, the doors return to their default positions, and the water valve opens water flow to the core. Pre-71 water valves are a bit different, IIRC. Somewhere around there, sorta ![]() Ooops, I see the OP is old as dirt. To answer the above question, the kick panel door assm. looks like this from the front. Here's the one at the upper cowl too. Neither are a "switch". They're vacuum operated, really cool stuff, IMO. The images don't show the vacuum lines. The RH kick panel door assembly for an A/C system includes a recirculated vacuum actuator, two brackets, one return spring with hooks, a link, two push-on nuts, four screws, and two hex nuts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-12-2023 at 02:13 AM. |
