It followed me home?
truck sat for a while, now the steering wheel is sticky
Why does that happen? I helped a friend move some trucks that have been sitting for a couple years and the steering wheels gets realy sticky, anybody know why?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: truck sat for a while, now the steering wheel is sticky
I Would Guess That The Oil From Peoples Hands Is Drawn Out From The Heat Of The Sun?
square body trucks an addiction or an investment either way they consume all my extra time and money |
Plus all the french fry grease coming to the surface.
-Scott- |
1962 C-10
My '73 is the same way... Sucks!!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
STILL PLAYS WITH TRUX
During all the years my truck sat idle the same thing happened to mine all i did is wiped it with 70% Isopropyl Alcohol and it worked well it may take several applications and dont be affraid to use alot of it.
Just don't use any Alcohol that's greater than 70% cuz it will leave a white residue behind and will damage some plastics......Ask me how i know this! |
Flat Black, & Chrome!
It was like that in my truck, all you gotta do is wipe it down, maybe spray some cleaner on it...
1962 C-10
Good info! My girl was trying to clean in the other day... still needs more.
Alcohol... it's the cure for many problems!!
I think you mean the cause of and the answer to.... ha
Thanks for the tip on the alcohol, I'll give it a shot
#9 | |
1962 C-10
The One And Only !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
