Old 03-23-2002, 12:34 PM   #1
DINS 1
DINS 1's Avatar
Post Drilling six lug pattern in a brake rotor
Has any one drilled a 5 lug rotor for the six lug bolt pattern? I have seen a lot of rear axles drilled for different bolt patterns.
72 3/4 ton 4x4 suburban
71 1/2 ton 4x4 suburban
69 1/2 ton 2wd suburban
79 Camaro RS black & white
92 GMC suburban 4x4
All in Webster City, IA
Wade
72 3/4 ton 4x4 Burb 6.0 LS Long term project
2024 Silverado CC SB DURAMAX.
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 03-23-2002, 01:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
If you have 6 lug rims your wanting to keep, you can get 6 lug rotors from GMC Paul.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-23-2002, 01:59 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
but if you wante dto do it then you oculd use a 4x4 rotor or 6 lug drum for holes pattern and weld up the 5 holes and grind smoooth and then dril 6 holes
can be done if you have the welder and grinder
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-23-2002, 09:57 PM   #4
Don Smith
Post
Don't do it, you won't be satisfied. I had a machine shop do mine, cost 80.00. Never used them. I purchased new rotors from Classic Performance Products.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
