Old 03-21-2008, 06:21 AM   #1
1980GMC
1980GMC's Avatar
Control Arms??
I've got a 5"/5" drop set up for my truck and read somewhere that with 3" spindles and 2" springs there might be rubbing between the wheel and the LCA.
I think it also mentioned that it only rubbed with 15" wheels, but cant remember.
Will there be rubbing if I run my 15" wheels? What size of wheel will not rub?
Also, the little crossmember right in front of the very rear X-member, and just behind the rear axle; can I cut that off without losing frame rigidity?
Wes
1980 GMC Sierra SCSB-2WD
1986 Chevrolet C10 SCSB-2WD
1980GMC is offline   Reply With Quote
Old 03-21-2008, 07:02 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Control Arms??
I was under the impression you shouldnt use lca's and spindles? I've got lca's and coils because I was trying to save up some money for spindles without having to change my 15" ralley's.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-21-2008, 07:05 AM   #3
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Control Arms??
I think he meant rubbing on the stock LCAs with the 3" spindle. I've heard a lot of people say that you need to do some trimming if planning to run 3" drop spindles with 15" wheels.
I've never tried it myself, but I read a lot. Hee hee. Rc415 and I believe bigblock73 both had problems with rubbing 15s and 3" drop spindles.
killthewabbit is offline   Reply With Quote
Old 03-21-2008, 07:12 AM   #4
cochino12
cochino12's Avatar
Re: Control Arms??
Your right, I cant read ha ha.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-21-2008, 10:29 AM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Control Arms??
yep on 3 inch spindles the caliper ears need to be grinded to clear 15 inch wheels
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-21-2008, 11:23 AM   #6
EN*PN78
EN*PN78's Avatar
Re: Control Arms??
Yes sir, I got 2.5 spindles and 2 drop springs with a coil cut out just to be crazy. I pushing as low as possible. Talk about rubbin and cut up inner fenders.
The lower control arms must be grinded down. Mine where a huge problem on the bottom side toward the back or cab. Only on big sharp turns. Easy fix though.
EN*PN78 is offline   Reply With Quote
Old 03-21-2008, 11:43 AM   #7
Hazieview
Building Dreams out of Dimes!
Re: Control Arms??
I have drop spindles and I noticed that my wheel wieghts keep grinding off. This is the reason I thought about getting bigger wheels. I wonder if I would have problems with 20s...?
Hazieview is offline   Reply With Quote
