03-21-2008, 06:08 PM | #1 |
New Blazer - New Member - New Questions
Hello all, I finally bought my dream truck...a 1972 blazer 350 auto 4x4. Price $1000. It was running in about 5 hours.
Non stock items: 1. 4" lift 2. 33" Dunlop "Dry rots" 3. custom steel 40 gallon fuel tank What I know it needs: 1. Rocker Boxes 2. Rocker Box caps 3. Inner rockers 4. Outer rockers 5. tailgate sheet metal 6. lower A pillar work 7. outer floor board driver and passenger 8. Passenger door lower inner and outer skin 9. new exhaust 10. Air injection tubes on Passenger side I will post some pictures later, but I am wondering what you all do if the rear sides of the blazer bow out just enough to where the tailgate won't latch? I am trying to figure out what structural components of the tub are supposed to reinforce this area. I also want to take the top off, but I am not sure if the dash and windshield will sag back. What I am planning on doing since it has a roll bar is to run two tubes from the top bar on the roll cage to the two attachment points on the top of the windshield frame where the hard top bolts on. How heavy is the hard top? is it a two/three person job? Does anyone ride with the doors off? I am not planning on building a monster truck, just a nice blazer that can take most of what the offroad can throw at it. My vision is a pastel light green with a white top, 33" tires, rhino lined interior, and my hot girlfriend in a bikini. Here are some pictures of the blazer the day I brought it home... http://picasaweb.google.com/mcsartin...wOld1972Blazer |
03-21-2008, 06:58 PM | #2 |
SKINNY TIRES RULE!
Re: New Blazer - New Member - New Questions
Welcome to the board from the Seattle area. Looks like you made a good purchase and got a great price!
The hard top is around 300 pounds. I'd suggest getting help so you don't drop it. I built a system like this so I could remove the top myself - it works great. Before you pull the top, you may want to consider some of the rust repairs. As soon as you pull the top, you may get some body sag, especially if you have rotted out rocker boxes, worn body mounts or rust in the windshield frame. If things are solid, and your body mounts aren't rotted out, you probably won't see much shifting. There are a few guys who have tied the roll cage into the windshield frame, but don't think it's really necessary. It would be better to tie it into the frame. Do a search for "roll cage" or "family cage" to get some ideas of what others have done. Oh, and while your taking more pictures, be sure to get that "bikini" shot...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-21-2008, 07:09 PM | #3 |
Project Junkie! Fishing Poor!!
I agree with the Bikini shots. on your purchace. By the way we stock just about all of the parts you are or will be looking for. I agree with bouncytruck, You will want to do your rockerboxes and rocker repair befor you remove your top. Not that it can't be done after, as many here can attest to, but it sure makes it easier to maintain your door openings... WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
03-21-2008, 07:30 PM | #4 |
Thanks for the welcome.
Bikini pics pending warm weather and top removed. The main problem i have with the tailgate is that the latching mechanism doesn't work. I need to free it up to be able to determine if it is actually bowed. Right now I am replacing the valve cover gaskets and exhaust manifold gaskets. Here in Maryland the Blazer is tagged as historic currently, I want to get it sound enough so it will pass the state inspection so it can be a daily driver behind my Goldwing. I am estimating that I will need about 500-700 in sheet metal if I buy it Repro but some stuff can be fixed by some sheet stock. I also recieved a soft top and an A/C system in the deal. I will be looking for a spare tire rack for the back because of the large fuel tank I have. Does anyone have an tips on adjusting the front wheel bearings? or where to get a new set? Thanks. |
03-21-2008, 07:06 PM | #5 |
Good looking K5 and it looks like you got a good deal on it. Blazers with minimal rust are hard to come by and your rust issues look about normal.
In relation to the rear bed sides bowing out, take a look at the rubber body mounts and see how worn they are and how the metal is in those areas. Seems they would have to be pretty bad to let the bed bow out. Good luck, welcome to the board and keep us posted as you move forward!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-13-2009, 07:24 AM | #6 | |
http://s74.photobucket.com/albums/i260/mcsartin/Blazer/ Passenger side Drivers Side Here is the best I can do for topless...Sorry for getting your hopes up guys I need to tackle the front Hub bearings in the next two weeks or so. Anyone have a good source? Tips or tricks are appreciated. Cheers Last edited by DreamBlaze; 01-13-2009 at 07:25 AM. |
01-13-2009, 11:09 AM | #7 |
I just had flash backs, good idea on the crash sheets.
03-21-2008, 08:33 PM | #8 |
SKINNY TIRES RULE!
Did I just see the words "bikini" and "top removed" in the same sentence?
You can get the wheel bearings from your local real parts store (not a schucks type store). You'll need a special socket to remove the front hubs, but you can pick them up at the store too. If you go with a stock (dealer installed) swing away spare, make sure you get the brackets that go inside the bed wall too. You'll have a hard time mounting it without them.
03-22-2008, 04:17 AM | #9 |
Welcome to board from San Antonio. nice find. Hope to see more pics. Mario.
03-22-2008, 05:42 AM | #10 |
Can't wait to retire!!
Welcome from Michigan, this is a great place with tons of very well informed truck guys and gals to learn from.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
03-22-2008, 06:29 AM | #11 |
67-72 parts collector,…
Welcome from central Missouri!
03-23-2008, 02:09 AM | #12 |
Old School, New Style
Welcome to the club. NOW POST SOME PICS (please)
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
03-23-2008, 03:48 AM | #14 |
from looks of the rear pics i would say your tailgate just needs cleaned up and lubed up
doesnt look bowed at all but i could be wrong is that a sunroof cut into that top?? |
03-23-2008, 06:05 AM | #15 |
welcome from maryland also . looks like you got the same red as my other blazer has .
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
01-13-2009, 07:12 AM | #16 |
01-13-2009, 05:54 AM | #17 |
Sorry for the Delay...a couple months. I am about ready to get into the blazer work now. Yes that is a sun roof cut into the top by PO...Ironc...a sun roof on a convertible?
03-23-2008, 09:17 AM | #18 |
Tot Roddin'
to the board from Mid-MO!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-23-2008, 03:55 PM | #19 |
Its lookin' like a Blazer!
Just looked at your pic link.... Looks like a nice start. How bad are your rocker boxes. Mine had some big holes cut out of them and some rust. For the most part they were solid so I just repaired and por15'd. They are solid as can be. Might save you some money if theres enough left to repair, lol.
03-23-2008, 05:40 PM | #20 |
Whats with the rear floor? The seats don't look too bad. The rest of the truck looks pretty typical of this vintage.
03-23-2008, 06:18 PM | #21 |
go cyclones
Nice find, welcome from chicago and central PA
03-23-2008, 06:54 PM | #22 |
Welcome to the group (and a new addiction) -
Looks like a nice truck. |
03-24-2008, 04:33 PM | #23 |
Your rear quarters do not appear out of alignment with the tailgate as the edges line up. Just pull, free up, lube and reinstall the tailgate latching mechanism of the tailgate. Setting up a rollbar with front windshield frame support is a common setup as Blazers tend to flex quite a bit even when they were new. You have to really support the body under the front floor --ie strong torque/rocker boxes, correct rubber shims etc. ensuring proper door alignment. The 300lb roof is structurally one of the better parts of the blazers but ----most guys prefer it topless (blazer or no blazer!hehehe). Soft tops are for the most part crap with poor fitting, junk plastic windows, and poor frames. Bikini tops from the windshield frame to the top of the roll bar seems to work except in winter. From the seat forward--just about everything is the same as the trucks. good luck--Huck
03-25-2008, 09:28 PM | #24 |
"1972 C5"
Welcome from socal!
01-13-2009, 06:08 AM | #25 | |
Do the doors have shims to adjust the gap at the top and bottom of the B pillar? I am working on some more detailed pictures so you can see what I am really working with. Cheers |
