10-28-2002, 07:58 PM | #1 |
Spindle Question
I put 2 1/2" drop spindles on and without any weight except for the frame the camber seems off. Is this normal? I don't remember which is negative or which s positive camber but the tops of the tires are leaning in.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
10-28-2002, 10:37 PM | #2 |
14.1 @ 96MPH
Mine ended up being slightly off the other direction - too much tilting out. My caster was pretty far off too, apparently, according to the printout I got from the alignment shop...
I wouldn't worry about it, just put plenty of new or good old parts on the front end, get it all together, and take it to an alignment shop. For $50, it's worth letting them do all the work and getting it really accurate.
Project1970 - LS1 Swap Complete! |
10-29-2002, 08:55 AM | #3 |
Do you have the big block in it yet or just a bare frame? The combination of springs and spindles you have will not settle down until you get some weight in it.
Rest in Peace Ed. Thanks for all the good times. |
10-29-2002, 09:15 AM | #4 |
That is what I thought, just wanted to make sure.
10-29-2002, 10:39 AM | #5 |
Almost Satisfied
I just replaced all the components on my front end and have four shims (thick ones) on each side. The left side camber looks pretty good with the shims, but the right side still has a lot of negative camber. I will wait until the motor and cab are back on before I do any more adjustments.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
