3/4 ton leaf spring
This is probably a stupid question, but i figure this board is the easiest way to get a complete answer. I have a set of 3/4 ton rear springs for an 87 suburban, and i was wondering if they would fit on my 83 K10? Thanks in advance for the help guys
1986 Chevy K10 4x4 305 Auto |
Re: 3/4 ton leaf spring
Robert Olson Transport
![]() Join Date: Oct 2002
measure them if they are the same eyelet to eyelet than they should
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
it seems like 3/4 tons and 1 tons had the same spring length, but the 1/2 tons are shorter? is this true?
from what i heard as well that 3/4 n 1 ton are 99% the same
3/4ton, and 1 ton both had the longer leaf springs.....56" I believe...
However the 1/2 ton truck came with either the 56" or the 52" springs depending on how they built the truck when it was new. You'll have to crawl under and measure eye bolt, to eye bolt, and compare them you can purchase 3/4 ton 7+1 leaf packs new in both the 52", and the 56". I recently purchased some 52" 7+1 leaf spring for my truck, it raised the back about 3.5", and the 3 leaf front springs raised the front 2.25". However there not cheap....the rears were $240/side, and the fronts were $170/side...these are new factory replacements of course. Just my 2 cents Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
Thanks alot Duro, thats actually some very helpful info
![]() Join Date: May 2007
I have a 86 1/2 and a 87 3/4, the 86 has 52" and the 87 has 56"
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
