03-23-2008, 04:03 PM | #1 |
traction bars
The bars are built by Calvert Racing,was just wondering if anyone has ever used them and how good they are,suppose to stop wheel hopping and axel wrap,appreciate any info....http://www.calvertracing.com/ here's the web page if you want to see them.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd Last edited by gmc67swb; 03-23-2008 at 05:39 PM. |
03-23-2008, 05:02 PM | #2 |
Retired Air Force Veteran
Re: traction bars
Check Site Link. Says It Can Not Be Found.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
03-23-2008, 05:07 PM | #3 |
Re: traction bars
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-23-2008, 05:42 PM | #4 | |
Re: traction bars
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
03-23-2008, 05:55 PM | #5 |
Re: traction bars
If they work at all (I`m sure they do) then they`ll stop wheel hop and the wheels will hook-up better.
03-23-2008, 08:23 PM | #6 |
2WD Jimmy
Re: traction bars
Have you ever thought about converting your leafs to trailing arms? It would be a bolt in. It would also improve handling/ride and eliminate the the need for traction bars.
Just a thought, Tom |
03-23-2008, 10:30 PM | #7 |
Re: traction bars
If your gonna go threw all that work to change over to trailing arms you could build yourself a set of lader bars. Or be like me and leave the leafs in a build a set of ladder bars and have both.
03-24-2008, 12:24 AM | #8 | |
Re: traction bars
Calverts traction-bars (aka Cal-Tracs) are in many <10.00 1320 cars so they do work. Will they work for you? That depends on what the current set-up is, what tuning has been done, & what gains you're expecting.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-24-2008 at 12:26 AM. |
