03-26-2008, 07:05 AM | #1 |
air ride suspension travel
how much suspension travel should one expect from a bag that ride hight is 5.5-7" ?? i mean when in the ride hight, bout how much suspension traval will the bag have?
03-26-2008, 08:42 AM | #2 |
Re: air ride suspension travel
If you look at slamspecialties.com, they have a listing of all the bags tech specs.
03-26-2008, 11:52 AM | #3 |
I believe firestone has them listed online as well. All the companies for that matter have them listed either on their site or other places online, each bag is different with amount of travel allowed.
I'd say generally itd be around 7 or so as middle ground inches for travel from when its full to dumped. I'd say that's a middle ground to lower end guestimate. All of them like rob said are online and you can look at the specific bag for the amount of travel you want/ need |
03-26-2008, 06:35 PM | #4 |
Each air bag has a specified ride height and a different amount of lift so it really depends on your brand and model of air bags. One thing though, it is important that you install the airbags at your designated ride height because the bags are designed to ride with a certain amount of air pressure and then need to be within the specs to get a good ride out of the air bags. I am sure you knew that but just double checking.
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
03-27-2008, 01:47 AM | #5 | |
Seņor Member
I'd say it's about 2" in either direction on a "normal" roadway, and slightly more (not much) when hitting bumps.
03-27-2008, 02:50 AM | #6 |
XXL- thats what i was looking for... and according to airride, he's right on... they said "normal condition" is about 1-2" and "extream" would be 4"
